Rabbit Anti-CD41绿光标记抗体, FITC conjugated
RICKY
Catalog Number : RSF-2636R-FITC
Quantity size : 100ug (2mg/ml,Lyophilized. Buffer = 0.01M PBS, pH 7.4 with 10mg/ml BSA and 0.1% Sodium azide. Reconstitute with 100ul sterile distilled water. )
background:
Integrin alpha 2b (CD41) is a calcium-dependent, noncovalently associated heterodimer and contains a heavy chain (GPIIb alpha) and a light chain (GPIIb beta) linked by a single disulfide bond. The Integrin alpha 2B chain interacts with the Integrin beta 3 subunit/CD61 to form the platelet glycoprotein complex, gpIIb/IIIa. It is expressed on platelets and megakaryocytes. Ligands for the gpIIb/IIIa heterodimer include fibrinogen, von Willebrand factor, fibronectin, vitronectin, and thrombospondin. The gpIIb/IIIa complex is the major Integrin on platelets and is important for platelet adhesion and aggregation.
Specificity : · anti-CD41 is a rabbit Polyclonal antibody, FITC conjugated
· specific for anti-CD41/FITC of rat and mouse.
· Protein G affinity chromatography purification, purity :>95%
· Isotype: IgG
· mol wt:125 kDa
Application :
Storage: Store at –20 oC for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20oC. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least two weeks at 2-4 oC.
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
