Anti- CD55/DAF抗人,鼠抗体说明书
Catalog Number :RS-1552R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent ) Background: This gene encodes a protein involved in the regulation of the complement cascade. The encoded glycoprotein is also known as the decay-accelerating factor (DAF); binding of DAF to complement proteins accelerates their decay, disrupting the cascade and preventing damage to host cells. Antigens present on the DAF glycoprotein constitute the Cromer blood group system (CROM). Two alternatively spliced transcripts encoding different proteins have been identified. The predominant transcript encodes a membrane-bound protein expressed on cells exposed to plasma component proteins but an alternatively spliced transcript produces a soluble protein present at much lower levels. Additional, alternatively spliced transcript variants have been described, but their biological validity has not been determined.Function : This protein recognizes C4b and C3b fragments that condense with cell-surface hydroxyl or amino groups when nascent C4b and C3b are locally generated during C4 and c3 activation. Interaction of daf with cell-associated C4b and C3b polypeptides interferes with their ability to catalyze the conversion of C2 and factor B to enzymatically active C2a and Bb and thereby prevents the formation of C4b2a and C3bBb, the amplification convertases of the complement cascade.Subunit : Monomer (major form) and non-disulfide-Anti- CD55/DAF抗人,鼠抗体说明书linked, covalent homodimer (minor form). Binds to coxsackievirus A21, coxsackieviruses B1, B3 and B5, human enterovirus 70, human echoviruses 6, 7, 11, 12, 20 and 21 capsid proteins and acts as a receptor for these viruses.
Subcellular Location : Isoform 1: Cell membrane; Single-pass type I membrane protein.
Isoform 2: Cell membrane; Lipid-anchor, GPI-anchor.Tissue Specificity : Expressed on the plasma membranes of all cell types that are in intimate contact with plasma complement proteins. It is also found on the surfaces of epithelial cells lining extracellular compartments, and variants of the molecule are present in body fluids and in extracellular matrix.Post-translational modifications : The Ser/Thr-rich domain is heavily O-glycosylated.Similarity : Belongs to the receptors of complement activation (RCA) family.Contains 4 Sushi (CCP/SCR) domains.Database links : UniProtKB/Swiss-Prot: P08174.4
.Specificity : Anti - CD55/DAF is a rabbit polyclonal antibody
specific for CD55/DAFof Human,
use for western blotting,elisa,immunoprecipitation and immunohistochemistry
– Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG mol wt: 35kDa
– Application :
– WB=1:100-500 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-500 IHC-F=1:100-500 IF=1:100-500 KLH conjugated synthetic peptide derived from human CD55
– not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
Anti-CD122/IL-2RB/PE??PE标记的白介素2受体β链抗体 IL-2Rβ
Anti-CD122/IL-2RB/HRP??辣根过氧化物酶标记的白介素2受体β链抗体 IL-2Rβ
Anti-CD122/IL-2RB/FITC??荧光素(FITC)标记的白介素2受体β链抗体 IL-2Rβ
Anti-CD122/IL-2RB/RBITC??罗丹明(RBITC)标记的白介素2受体β链抗体 IL-2Rβ
Anti-CD122/IL-2RB/Biotin ??生物素标记的白介素2受体β链抗体 IL-2Rβ
Anti-CD26/Cy3??荧光素(Cy3)标记的CD26抗体
Anti-CD26/Cy5??Cy5标记的CD26抗体
Anti-CD26/PE??PE标记的CD26抗体
Anti-CD26/FITC??荧光素(FITC)标记的CD26抗体
Anti-CD26/HRP??辣根过氧化物酶标记的CD26抗体
Anti-CD26/RBITC??罗丹明(RBITC)标记的CD26抗体
Anti-CD26/Biotin ??生物素标记的CD26抗体
Anti-IL-2R gamma/CD132/Cy3??Cy3标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/Cy5??Cy5标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/PE??PE标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/FITC??FITC标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/HRP??辣根过氧化物酶标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/RBITC??罗丹明(RBITC)标记的白介素2受体γ链抗体
Anti-IL-2R gamma/CD132/Biotin??生物素标记的白介素2受体γ链抗体
Anti-TBRG1/Cy5??Cy5标记的转化生长因子β调节蛋白1抗体
Anti-CD272/BTLA/Cy3??荧光素(Cy3)标记的B和T淋巴细胞衰减蛋白抗体
Anti-CD272/BTLA/RBITC??罗丹明(RBITC)标记的B和T淋巴细胞衰减蛋白抗体
Anti-TBRG1/Cy3??荧光素(Cy3)标记的转化生长因子β调节蛋白1抗体
Anti-CD272/BTLA/PE??PE标记的B和T淋巴细胞衰减蛋白抗体
Anti-TBRG1/PE??PE标记的转化生长因子β调节蛋白1抗体
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
