Rabbit Anti-IAA抗体,IAA说明书antibody
Catalog Number :RS-90902R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent )
background:
Indole-3-acetic acid, also known as IAA, is a heterocyclic compound that is an phytohormones
called auxins. This colourless solid is probably the most important plant auxin. The molecule is
derived from indole, containing a carboxymethyl group (acetic acid). IAA has many different
effects, as all auxins do, such as inducing cell elongation and cell division with all subsequent
results for plant growth and development. There are less expensive and metabolically stable
synthetic auxin analogs on the market for use in horticulture, such as indole-3-butyric acid (IBA)
and 1-naphthaleneacetic acid (NAA).
Specificity :
–Anti-IAA is a rabbit polyclonal antibody
–specific for anti-IAA of Citrus reticulata Blanco,Tomato
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
–Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
Application :
– WB=1:100-500
– ELISA=1:500-1000
– IHC-P=1:100-500
– IHC-F=1:100-500Anti-IAA抗体,IAA说明书– IF=1:50-200
– not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20 ℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized
antibody is stable at room temperature for at least one month and for greater than a year when kept
at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is
stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human,
therapeutic or diagnAnti-IAA抗体,IAA说明书ostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
