Goat Anti-Perilipin标记抗体专家, FITC conjugated
Catalog Number : RSF-3789R-FITC
Quantity size : 100ug (2mg/ml,Lyophilized. Buffer = 0.01M PBS, pH 7.4 with 10mg/ml BSA and 0.1% Sodium azide. Reconstitute with 100ul sterile distilled water. )
background:
Perilipins, members of the PAT protein family (named after lipid droplet proteins Perilipin, Adipophilin, and TIP47) are found exclusively at the surface of lipid droplets in adipocytes and steroidogenic cells. They have been suggested to function as regulators of lipolysis and triacylglycerol storage within adipose tissue. Four distinct isoforms ranging from perilipin A (57 kDa) to perilipin D (26 kDa) have been identified and they share an identical amino terminal sequences, and contain 2–6 consensus protein kinase A (PKA) phosphorylation sites. Perilipin C and D have been detected only in steroidogenic cells. Perilipin A is the most abundant form on the lipid droplets of adipocytes. The phosphorylation of perilipin by PKA, which is accompanied by the phosphorylation and translocation of hormone-sensitive lipase from the cytosol to the lipid droplets, promotes lipolysis. There is evidence for the presence of perilipin A in atheroma plaques suggesting that the protein may be involved in the development of therosclerosis by controlling as in adipocytes the hydrolysis of stored lipids.
Specificity : · anti-Perilipin is a Goat Polyclonal antibody, FITC conjugated
· specific for anti-Perilipin/FITC of rat and mouse.
· Protein G affinity chromatography purification, purity :>95%
· Isotype: IgG
· mol wt:57 kDa
Application :
Storage: Store at –20 oC for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20oC. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least two weeks at 2-4 oC.
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
