Goat Anti-TNFAIP3特惠抗体 antibody
Catalog Number :RS-92803R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent )
Background:A20 is a Cys2/Cys2 zinc finger protein that is induced by a variety of
inflammatory stimuli and regulates gene expression. Specifically, A20 is induced by tumor
necrosis factor (TNF) and interleukin 1 (IL-1), and acts as a negative regulator of nuclear
factor κ B (NFκB) gene expression. By inhibiting NFκB activation, A20 plays a critical
role in terminating NFκB responses to various stimuli. Although the C-terminal region of
A20 contains seven zinc finger domains, only four of these domains are required for in vitro
inhibition of TNF-induced NFκB activation. A20 also interacts with several other proteins,
such as TRAF2, TRAF6 and IkB kinase (IKK) γ protein, and can thereby inhibit cell death.
TXBP151, a novel A20-binding protein, may mediate the anti-apoptotic activity of A20.
Involved in the negative feedback regulation of signal transduction, A20 and A20-binding
proteins may be useful as novel therapeutic tools in the treatment of a variety of diseases
Function:TNFAIP3特惠抗体
TNFAIP3 interacts with NAF1 and inhibits TNF induced NF kappa B dependent gene
expression by interfering with a RIP or TRAF2 mediated transactivation signal. It inhibits
programmed cell death, has a role in the function of the lymphoid system, and may contribute
to the in vivo effects of TNF.
Specificity : Anti-TNFAIP3 is a goat polyclonal antibody
specific for TNFAIP3 of Rabbit, Mouse, Rat
use for western blotting,elisa,immunoprecipitation and immunohistochemistry
– Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt: 90 kDa
Application :TNFAIP3特惠抗体
– WB=1:100-500 ELISA=1:2000-5000 IP=1:100-500 IHC-P=1:100-500 IHC-F=1:100-500
– not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized
antibody is stable at room temperature for at least one month and for greater than a year
when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody,
the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in
human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
