Rabbit Anti-DCHS1抗体,DCHS1抗体说明书 antibody
Catalog Number :RS-90199R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent ) Background: background:
The cadherins are a family of Ca2+-dependent adhesion molecules that function to mediate cell-cell binding critical to the maintenance of structure and morphogenesis. Cadherins each contain a large extracellular domain at the N-terminus, which is characterized by a series of five homologous repeats, the most distal of which is thought to be responsible for binding specificity. DCHS1 (dachsous 1), also known as CDH19, CDH25, FIB1, KIAA1773 or PCDH16, is a 3,298 amino acid single-pass type I membrane protein that contains 27 cadherin domains and belongs to the cadherin superfamily. Expressed specifically in fibroblasts, DCHS1 functions as a Ca2+-dependent cell-cell (specifically fibroblast-fibroblast) adhesion protein that may be involved in wound healing. The gene encoding DCHS1 maps to human chromosome 11, which houses over 1,400 genes and comprises nearly 4% of the human genome.
Specificity :
–Anti-DCHS1 is a rDCHS1抗体,DCHS1抗体说明abbit polyclonal antibody
–specific for DCHS1 of rat ,mo ,hu,zebra fish
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
–Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt: 342kDa
Application :
– WB=1:100-500
– ELISA=1:500-1000
– IHC-P=1:100-500 IHC-F=1:100-500 IF=1:100-500
– not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
DCHS1抗体,DCHS1抗体说明
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
