Mouse Anti-phospho-JNK1 (Thr183)一抗 antibody
Catalog Number : RS-97591R
Quantity size : 0.1ml (dilute with pH7.4 0.01 M PBS or antibody diluent )
Background: The protein encoded by this gene is a member of the MAP kinase family. MAP
kinases act as an integration point for multiple biochemical signals, and are involved in a wide
variety of cellular processes such as proliferation, differentiation, transcription regulation and
development. This kinase is activated by various cell stimuli, and targets specific transcription
factors, and thus mediates immediate-early gene expression in response to cell stimuli. The
activation of this kinase by tumor-necrosis factor alpha (TNF-alpha) is found to be required for
TNF-alpha induced apoptosis. This kinase is also involved in UV radiation induced apoptosis,
which is thought to be related to cytochrom c-mediated cell death pathway. Studies of the mouse
counterpart of this gene suggested that this kinase play a key role in T cell proliferation,
apoptosis and differentiation. Five alternatively spliced transcript variants encoding distinct
isoforms have been reported. [provided by RefSeq, Jun 2013]
Function:
Responds to activation by environmental stress and pro-inflammatory cytokines by
phosphorylating a number of transcription factors, primarily components of AP-1 such as JUN,
JDP2 and ATF2 and thus regulates AP-1 transcriptional activity. In T-cells, JNK1 and JNK2 are
required for polarized differentiation of T-helper cells into Th1 cells (By similarity).
Phosphorylates heat shock factor protein 4 (HSF4). JNK1 isoforms display different binding
patterns: beta-1 preferentially binds to c-Jun, whereas alpha-1, alpha-2, and beta-2 have a simphospho-JNK1 (Thr183)一抗ilar
low level of binding to both c-Jun or ATF2. However, there is no correlation between binding
and phosphorylation, which is achieved at about the same efficiency by all isoforms.
pecificity :
– Anti-phospho-JNK1 (Thr183) is a mouse monoclonal antibody
– specific for phospho-JNK1 (Thr183) of rabbit
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
– Protein A affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt: 50 kDa
Application :
– Western blotting 1:100-500
– Immunohistochemistry 1:100-500
– ELISA 1:500-1000
– Optimal working dilutions must be determined by the end user.
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The
lyophilized antibody is stable at room temperature for at least one month and for
greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M
PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for
use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
