ATP6V1B2蛋白抗体促销
『别名』ATP6B1B2; ATP6B2; ATP6V1 B2; ATP6V1B 2; ATP6V1B2; ATPase H+ transporting lysosomal 56/58kDa V1 subunit B isoform 2; ATPase H+ transporting lysosomal 56/58kDa V1 subunit B2; ATPase H+ transporting, lysosomal (vacuolar proton pump) beta polypeptide 56/58kD isoform 2; ATPase, H+ transporting, lysosomal V1 subunit B2; brain isoform; Endomembrane proton pump 58 kDa subunit; H+ transporting two sector ATPase; HO 57; HO57; V ATPase B2 subunit; V ATPase subunit B 2; V type proton ATPase subunit B, brain isoform; V-ATPase subunit B 2; V-type proton ATPase subunit B; Vacuolar ATP synthase subunit B brain isoform; Vacuolar H+ ATPase 56,000 subunit; Vacuolar H+ ATPase 56000 subunit; Vacuolar H+ATPase B2; Vacuolar proton pump subunit B 2; VAT B2; VATB 2; VATB; VATB2; VATB2_HUMAN; Vma 2; Vma2; VPP 3; VPP3.
『浓度』1mg/1ml
『规格』0.2ml/200μg
『抗体来源』Rabbit
『克隆类型』polyclonal
『交叉反应』Human, Mouse, Rat, Chicken, Dog, Pig, Cow, Horse, Rabbit, Sheep, Cynomolgus Monkey, Orangutan
『产品类型』一抗
『研究领域』ATP6V1B2蛋白抗体促销 肿瘤 细胞生物 免疫学 神经生物学 信号转导 新陈代谢 表观遗传学
『蛋白分子量』predicted molecular weight: 56kDa
『性状』Lyophilized or Liquid
『免疫原』KLH conjugated synthetic peptide derived from human ATP6V1B2/V-ATPase B2
『亚型』IgG
『纯化方法』affinity purified by Protein A
『储存液』Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
『产品应用』WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
『保存条件』Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
『产品介绍』Vacuolar-type H+-ATPase (V-ATPase) is a multisubunit enzyme responsible for acidification of eukaryotic intracellular organelles. V-ATPases pump protons against an electrochemical gradient, while F-ATPases reverse the process, thereby synthesizing ATP. A peripheral V1 domain, which is responsible for ATP hydrolysis, and a integral V0 domain, which is responsible for proton translocation, compose V-ATPase. Nine subunits (A–H) make up the V1 domain and five subunits (a, d, c, c' and c") make up the V0 domain. Like F-ATPase, V-ATPase most likely operates through a rotary mechanism. The V-ATPase V1 B subunit exists as two isoforms. In the inner ear, the V-ATPase B1 isoform functions in proton secretion and is required to maintain proper endolymph pH and normal auditory function. The gene encoding the human V-ATPase B1 isoform maps to chromosome 2cen-q13. Mutations in this gene cause distal renal tubular acidosis associated with sensorineural deafness. The V-ATPase B2 isoform is expressed in kidney and is the only B isoform expressed in osteoclasts. The gene encoding the human V-ATPase B2 isoform maps to chromosome 8p22-p21.
Function : Non-catalytic subunit of the peripheral V1 complex of vacuolar ATPase. V-ATPase is responsible for acidifying a variety of intracellular compartments in eukaryotic cells.
Subunit : V-ATPase is a heteromultimeric enzyme composed of a peripheral catalytic V1 complex (main components: subunits A, B, C, D, E, and F) attached to an integral membrane V0 proton pore complex (main component: the proteolipid protein).
Subcellular Location : Endomembrane system. Melanosome. Endomembrane. Identified by mass spectrometry in melanosomeATP6V1B2蛋白抗体促销 fractions from stage I to stage IV.
Similarity : Belongs to the ATPase alpha/beta chains family.
Database links : UniProtKB/Swiss-Prot: P21281.3
探讨转化生长因子β1与胆囊癌的发展关系
ELISA试剂盒的质量控制分析
交变应力对大鼠翼外肌成肌细胞形态学改建的影响
天麻素对大鼠骨骼肌细胞化学损伤的保护
