筱晓声光调制器允许用户改变输出光振幅、持续时间和周期/频率。插入损耗可低至2 dB,消光比可高达50 dB,上升时间可低至5纳秒,周期性可高达数百MHA。应用包括开关、脉冲拾取、快速衰减器等。波长范围从近紫外到近红外。
产品特点:
0级光和1级光光纤输出
高消光比
可根据客户波长和频率的不同制作不同的器件
应用领域:
BODTR
DVS
光开关
产品参数:
型号 |
波长 (nm) |
频率 (Mhz) |
通光孔径 (mm) |
衍射效率 (%) |
光功率密度 (W/mm²) |
驱动功率 (W) |
输入阻抗 (Ω) |
电压驻波比 |
A-532-80-L-T-D1-T-A-K |
532 |
80 |
1 |
85 |
250 |
0.8 |
50 |
<1.3:1 |
A-532-80-L-T-D2-T-A-K |
532 |
80 |
2 |
85 |
250 |
1.5 |
50 |
<1.3:1 |
A-532-100-L-T-D1-T-A-K |
532 |
100 |
1 |
85 |
250 |
0.8 |
50 |
<1.3:1 |
A-532-200-L-T-D0.3-T-A-K |
532 |
200 |
0.3 |
70 |
250 |
2 |
50 |
<1.5:1 |
A-532-200-L-T-D4-T-A-K |
532 |
200 |
4 |
80 |
250 |
4 |
50 |
<1.5:1 |
A-632-80-L-T-D1-T-A-K |
632 |
80 |
1 |
85 |
250 |
0.8 |
50 |
<1.3:1 |
A-632-100-L-T-D1-T-A-K |
632 |
100 |
1 |
85 |
250 |
0.8 |
50 |
<1.3:1 |
A-632-200-L-T-D0.3-T-A-K |
632 |
200 |
0.3 |
70 |
250 |
2.5 |
50 |
<1.5:1 |
A-632-200-L-T-D1-T-A-K |
632 |
200 |
1 |
85 |
250 |
1.5 |
50 |
<1.5:1 |
A-780-110-L-T-D1-T-A-K |
780 |
110 |
1 |
85 |
250 |
1.3 |
50 |
<1.3:1 |
A-780-150-L-T-D1-T-A-K |
780 |
150 |
1 |
75 |
250 |
2 |
50 |
<1.3:1 |
A-780-150-L-T-D2-T-A-K |
780 |
150 |
2 |
75 |
250 |
2.5 |
50 |
<1.5:1 |
A-780-200-L-T-D0.3-T-A-K |
780 |
200 |
0.3 |
70 |
250 |
3 |
50 |
<1.5:1 |
A-780-200-L-T-D2-T-A-K |
780 |
200 |
2 |
70 |
250 |
3.5 |
50 |
<1.5:1 |
A-850-110-L-T-D0.7-T-A-K |
850 |
110 |
0.7 |
80 |
250 |
1 |
50 |
1.2:1 |
A-850-200-L-T-D0.3-T-A-K |
850 |
200 |
0.3 |
80 |
250 |
3 |
50 |
<1.5:1 |
A-1064-100-L-T-D0.7-T-A-K |
1064 |
100 |
0.7 |
85 |
250 |
1.8 |
50 |
1.2:1 |
A-1064-120-L-T-D0.7-T-A-K |
1064 |
120 |
0.7 |
85 |
250 |
1.8 |
50 |
<1.3:1 |
A-1064-150-L-T-D0.5-T-A-K |
1064 |
150 |
0.5 |
85 |
250 |
2.5 |
50 |
<1.3:1 |
A-1064-200-L-T-D0.3-T-A-K |
1064 |
200 |
0.3 |
70 |
250 |
2.5 |
50 |
<1.3:1 |
A-1550-40-L-T-D0.7-T-A-K |
1550 |
40 |
0.7 |
80 |
250 |
2.5 |
50 |
<1.3:1 |
A-1550-60-L-T-D0.5-T-A-K |
1550 |
60 |
0.5 |
80 |
250 |
2.5 |
50 |
<1.3:1 |
A-1550-80-L-T-D0.7-T-A-K |
1550 |
80 |
0.7 |
80 |
250 |
2.5 |
50 |
<1.3:1 |
A-1550-150-L-T-D0.5-T-A-K |
1550 |
150 |
0.5 |
65 |
250 |
2.5 |
50 |
<1.5:1 |
A-1550-200-L-T-D0.3-T-A-K |
1550 |
200 |
0.3 |
55 |
250 |
3 |
50 |
<1.5:1 |
可给客户提供定制服务:波长500-2000nm可选任意波段.频率40-300MhA可选任意频率,频率精度可定制。通光孔径0.1-4mm可定制,外壳尺寸可以按照客户系统要求定制合适的外壳尺寸包含外壳材料。可满足客户对某一指标要求进行优化器件。 |
尺寸图:
AOM Modulator
RF Driver
订购信息(参考表格型号)
光纤为何会损伤?浅谈一下光纤损伤阈值 - 筱晓小课堂
半空间对穿反射式碳排放监测系统 - 筱晓小课堂
紧凑型波长计!高精度、易操作、体积小!- 筱晓光子新品速递⑮
衍射光学元件 DOE 介绍与分类 - 筱晓光子实验室
MCML-100/MCML-120A SERIES 无掩膜数字光刻机 Digit
λ-Rapid 1040高速无ASE可调谐二极管激光器
λ-Rapid 950高速无ASE可调谐二极管激光器
ISDI 晶圆级CMOS图像传感器(用于X射线环境) 分辨率2173 x 2201
1420nm FP高功率激光器 带FBG 500mW(Anristu)
Anritsu SLD激光器 1550nm
Anritsu SLD激光器 840nm
640B绝对压力控制器
Eravant WR-10波导台式RF功率放大器 CITLF3硅锗低噪声/宽带脉冲电信号/RF放大器
974nm 360mw 低功率单模泵浦FP激光器 Lumentum
974/976nm 高功率单模泵浦FP激光器
THz反射镜片
nLIGHT LIEKKI Passive系列 无源光纤 Passive-30/250-P
OCT光栅 体相全息衍射光栅 VPH 美国 Wasatch Photonics
633nm窄线宽Mini激光二极管模块 / 1950nm SLD 台式光源
