筱晓声光调制器允许用户改变输出光振幅、持续时间和周期/频率。插入损耗可低至2 dB,消光比可高达50 dB,上升时间可低至5纳秒,周期性可高达数百MHA。应用包括开关、脉冲拾取、快速衰减器等。波长范围从近紫外到近红外。
产品特点:
0级光和1级光光纤输出
高消光比
可根据客户波长和频率的不同制作不同的器件
应用领域:
BODTR
DVS
光开关
产品参数:
型号 | 波长 (nm) | 频率 (Mhz) | 通光孔径 (mm) | 衍射效率 (%) | 光功率密度 (W/mm²) | 驱动功率 (W) | 输入阻抗 (Ω) | 电压驻波比 |
A-532-80-L-T-D1-T-A-K | 532 | 80 | 1 | 85 | 250 | 0.8 | 50 | <1.3:1 |
A-532-80-L-T-D2-T-A-K | 532 | 80 | 2 | 85 | 250 | 1.5 | 50 | <1.3:1 |
A-532-100-L-T-D1-T-A-K | 532 | 100 | 1 | 85 | 250 | 0.8 | 50 | <1.3:1 |
A-532-200-L-T-D0.3-T-A-K | 532 | 200 | 0.3 | 70 | 250 | 2 | 50 | <1.5:1 |
A-532-200-L-T-D4-T-A-K | 532 | 200 | 4 | 80 | 250 | 4 | 50 | <1.5:1 |
A-632-80-L-T-D1-T-A-K | 632 | 80 | 1 | 85 | 250 | 0.8 | 50 | <1.3:1 |
A-632-100-L-T-D1-T-A-K | 632 | 100 | 1 | 85 | 250 | 0.8 | 50 | <1.3:1 |
A-632-200-L-T-D0.3-T-A-K | 632 | 200 | 0.3 | 70 | 250 | 2.5 | 50 | <1.5:1 |
A-632-200-L-T-D1-T-A-K | 632 | 200 | 1 | 85 | 250 | 1.5 | 50 | <1.5:1 |
A-780-110-L-T-D1-T-A-K | 780 | 110 | 1 | 85 | 250 | 1.3 | 50 | <1.3:1 |
A-780-150-L-T-D1-T-A-K | 780 | 150 | 1 | 75 | 250 | 2 | 50 | <1.3:1 |
A-780-150-L-T-D2-T-A-K | 780 | 150 | 2 | 75 | 250 | 2.5 | 50 | <1.5:1 |
A-780-200-L-T-D0.3-T-A-K | 780 | 200 | 0.3 | 70 | 250 | 3 | 50 | <1.5:1 |
A-780-200-L-T-D2-T-A-K | 780 | 200 | 2 | 70 | 250 | 3.5 | 50 | <1.5:1 |
A-850-110-L-T-D0.7-T-A-K | 850 | 110 | 0.7 | 80 | 250 | 1 | 50 | 1.2:1 |
A-850-200-L-T-D0.3-T-A-K | 850 | 200 | 0.3 | 80 | 250 | 3 | 50 | <1.5:1 |
A-1064-100-L-T-D0.7-T-A-K | 1064 | 100 | 0.7 | 85 | 250 | 1.8 | 50 | 1.2:1 |
A-1064-120-L-T-D0.7-T-A-K | 1064 | 120 | 0.7 | 85 | 250 | 1.8 | 50 | <1.3:1 |
A-1064-150-L-T-D0.5-T-A-K | 1064 | 150 | 0.5 | 85 | 250 | 2.5 | 50 | <1.3:1 |
A-1064-200-L-T-D0.3-T-A-K | 1064 | 200 | 0.3 | 70 | 250 | 2.5 | 50 | <1.3:1 |
A-1550-40-L-T-D0.7-T-A-K | 1550 | 40 | 0.7 | 80 | 250 | 2.5 | 50 | <1.3:1 |
A-1550-60-L-T-D0.5-T-A-K | 1550 | 60 | 0.5 | 80 | 250 | 2.5 | 50 | <1.3:1 |
A-1550-80-L-T-D0.7-T-A-K | 1550 | 80 | 0.7 | 80 | 250 | 2.5 | 50 | <1.3:1 |
A-1550-150-L-T-D0.5-T-A-K | 1550 | 150 | 0.5 | 65 | 250 | 2.5 | 50 | <1.5:1 |
A-1550-200-L-T-D0.3-T-A-K | 1550 | 200 | 0.3 | 55 | 250 | 3 | 50 | <1.5:1 |
可给客户提供定制服务:波长500-2000nm可选任意波段.频率40-300MhA可选任意频率,频率精度可定制。通光孔径0.1-4mm可定制,外壳尺寸可以按照客户系统要求定制合适的外壳尺寸包含外壳材料。可满足客户对某一指标要求进行优化器件。 |
尺寸图:
AOM Modulator
RF Driver
订购信息(参考表格型号)
光纤为何会损伤?浅谈一下光纤损伤阈值 - 筱晓小课堂
半空间对穿反射式碳排放监测系统 - 筱晓小课堂
紧凑型波长计!高精度、易操作、体积小!- 筱晓光子新品速递⑮
衍射光学元件 DOE 介绍与分类 - 筱晓光子实验室
MCML-100/MCML-120A SERIES 无掩膜数字光刻机 Digit
CO2激光光谱分析仪 9.1-11.3um
DUMA 光束分析仪 BeamOn HR 1 Inch (UV to 1350n
ISDI 晶圆级CMOS图像传感器(用于X射线环境) 分辨率2173 x 2201
1420nm FP高功率激光器 带FBG 500mW(Anristu)
Anritsu SLD激光器 1550nm
Anritsu SLD激光器 840nm
640B绝对压力控制器
Eravant WR-10波导台式RF功率放大器 CITLF3硅锗低噪声/宽带脉冲电信号/RF放大器
974nm 360mw 低功率单模泵浦FP激光器 Lumentum
974/976nm 高功率单模泵浦FP激光器
SESAM 可饱和吸收镜(半饱和吸收片) 1064nm
nLIGHT LIEKKI Passive系列 无源光纤 Passive-30/250-P
OCT光栅 体相全息衍射光栅 VPH 美国 Wasatch Photonics
633nm窄线宽Mini激光二极管模块 / 1950nm SLD 台式光源
