方案下载应用领域 | 环保 |
检测样本 | 空气 |
检测项目 | 其他>其它 |
参考标准 | 无 |
CUSTOMER PROBLEM:Many possible terrorist threats have been identified by the Department of Homeland Security, among which is the use of Toxic Industrial Chemicals (TICs) to either harm building occupants or cause business disruptions. In order to maintain a level of security for populated buildings, a continuous air monitoring system should be employed in the building air handling systems or at entrances, mail rooms, and shipping docks. Initial systems deployed for TIC detection used monitoring technologies which have been found to lack the sensitivity or selectivity to make them useful against multiple chemical threat sources in the presence of interferents such as common solvents and cleaners. These interferents have often resulted in a large number of false alarms which are costly and reduce the overall customer satisfaction with the monitoring system. An analyzer that can detect multiple agents very quickly with no, or extremely infrequent, false alarms will enhance the utility and security protection offered by these ambient air monitors for homeland security applications.
氢还原反应过程监测- MKS Cirrus 2
Infrared analysis of E85 engines
催化排放FTIR监测
