方案下载应用领域 | 其他 |
检测样本 | |
检测项目 | |
参考标准 | 无 |
CUSTOMER CHALLENGES: 1.Reducing catalyst performance testing time; 2. Reducing development time and costs; 3. Maintenance of multiple analytical instruments; 4. Accurate measurement of low level NOx; 5. Speciation of gas components directly without gas conditioning... BACKGROUND Currently, new catalyst performance evaluations require numerous analytical instruments to measure all species at varying load levels. These analyzers are expensive, costly and time-consuming to maintain, and for many, require extensive sample conditioning. For example, most analyzers require that the moisture level be very low for the instrument to work properly. This sample conditioning has been shown to provide systematic errors in NOx measurements. Also some gases such as NH3 cannot be measured directly. In this case NH3 is converted to NOx and then analyzed which adds even more complexity and greater potential for systematic error.
氢还原反应过程监测- MKS Cirrus 2
环境有毒气体实时监测
Infrared analysis of E85 engines
