激肽释放酶4(KLK4)检测试剂盒
适用生物 Rattus norvegicus (Rat,大鼠)
激肽释放酶4(KLK4)检测试剂盒
检测范围 0.156-10ng/mL 灵敏度 0.049ng/mL
样本类型 Serum, plasma and other biological fluids.
实验时长 4.5h 实验方法 双抗夹心法 激肽释放酶4(KLK4)检测试剂盒
规格 96T
ELISA Kit for Kallikrein 4 (KLK4)
FOR IN VITRO AND RESEARCH USE ONLY, NOT FOR USE IN CLINICAL DIAGNOSTIC PROCEDURES!
Organism species Rattus norvegicus (Rat)
激肽释放酶4(KLK4)检测试剂盒
Sample type Serum, plasma and other biological fluids.
Format 96-well strip plate
Assay length 4.5 hours
Detection range 0.156-10ng/mL The standard curve concentrations used for the ELISA’s were 10ng/mL, 5ng/mL, 2.5ng/mL, 1.25ng/mL, 0.625ng/mL, 0.313ng/mL, 0.156ng/mL
Sensitivity The minimum detectable dose of this kit is typically less than 0.049ng/mL.
Specificity
This assay has high sensitivity and excellent specificity for detection of Kallikrein 4 (KLK4).
No significant cross-reactivity or interference between Kallikrein 4 (KLK4) and analogues was observed.
Recovery
Matrices listed below were spiked with certain level of recombinant Kallikrein 4 (KLK4) and the recovery rates were calculated by comparing the measured value to the expected amount of Kallikrein 4 (KLK4) in samples.
Matrix Recovery range (%) Average(%)
serum(n=5) 89-98 94
EDTA plasma(n=5) 78-95 83
heparin plasma(n=5) 84-103 88
Precision
Intra-assay Precision (Precision within an assay): 3 samples with low, middle and high level Kallikrein 4 (KLK4) were tested 20 times on one plate, respectively.
Inter-assay Precision (Precision between assays): 3 samples with low, middle and high level Kallikrein 4 (KLK4) were tested on 3 different plates, 8 replicates in each plate.
CV(%) = SD/meanX100
Intra-Assay: CV<10%
Inter-Assay: CV<12%
Linearity
The linearity of the kit was assayed by testing samples spiked with appropriate concentration of Kallikrein 4 (KLK4) and their serial dilutions. The results were demonstrated by the percentage of calculated concentration to the expected.
Sample 1:2 1:4 1:8 1:16
serum(n=5) 96-104% 96-103% 99-105% 98-105%
EDTA plasma(n=5) 79-94% 83-91% 97-105% 83-103%
heparin plasma(n=5) 90-97% 93-101% 84-94% 86-93%
Stability
The stability of kit is determined by the loss rate of activity. The loss rate of this kit is less than 5% within the expiration date under appropriate storage condition.
To minimize extra influence on the performance, operation procedures and lab conditions, especially room temperature, air humidity, incubator temperature should be strictly controlled. It is also strongly suggested that the whole assay is performed by the same operator from the beginning to the end.
Reagents and materials provided
Reagents Quantity Reagents Quantity
Pre-coated, ready to use 96-well strip plate 1 Plate sealer for 96 wells 4
Standard 2 Standard Diluent 1×20mL
Detection Reagent A 1×120μL Assay Diluent A 1×12mL
Detection Reagent B 1×120μL Assay Diluent B 1×12mL
TMB Substrate 1×9mL Stop Solution 1×6mL
Wash Buffer (30 × concentrate) 1×20mL Instruction manual 1
Assay procedure summary
1. Prepare all reagents, samples and standards;
2. Add 100μL standard or sample to each well. Incubate 2 hours at 37oC;
3. Aspirate and add 100μL prepared Detection Reagent A. Incubate 1 hour at 37oC;
4. Aspirate and wash 3 times;
5. Add 100μL prepared Detection Reagent B. Incubate 30 minutes at 37oC;
6. Aspirate and wash 5 times;
7. Add 90μL Substrate Solution. Incubate 15-25 minutes at 37oC;
8. Add 50μL Stop Solution. Read at 450nm immediately.
Test principle
The test principle applied in this kit is 激肽释放酶4(KLK4)检测试剂盒Sandwich enzyme immunoassay. The microtiter plate provided in this kit has been pre-coated with an antibody specific to Kallikrein 4 (KLK4). Standards or samples are then added to the appropriate microtiter plate wells with a biotin-conjugated antibody specific to Kallikrein 4 (KLK4). Next, Avidin conjugated to Horseradish Peroxidase (HRP) is added to each microplate well and incubated. After TMB substrate solution is added, only those wells that contain Kallikrein 4 (KLK4), biotin-conjugated antibody and enzyme-conjugated Avidin will exhibit a change in color. The enzyme-substrate reaction is terminated by the addition of sulphuric acid solution and the color change is measured spectrophotometrically at a wavelength of 450nm ± 10nm. The concentration of Kallikrein 4 (KLK4) in the samples is then determined by comparing the O.D. of the samples to激肽释放酶4(KLK4)检测试剂盒 the standard curve.
H9人胚胎干细胞培养方法
细胞百科之----口腔上皮细胞
钰博开学季 | 888元抢购细胞培养新装备
细胞学堂 | 直击细胞培养试剂四大疑难问题
小鼠氢/钾离子交换ATP酶β肽检测试剂盒,ATP4β试剂盒
小鼠丙酮酸羧化酶检测试剂盒,PC试剂盒
小鼠海藻糖酶检测试剂盒,TREH试剂盒
小鼠含铜胺氧化酶3检测试剂盒,AOC3试剂盒
小鼠补体成分4b检测试剂盒,C4b试剂盒
小鼠前蛋白转化酶枯草溶菌素9检测试剂盒,PCSK9试剂盒
小鼠双特异性磷酸酶1检测试剂盒,DUSP1试剂盒
小鼠巯基丙酮酸硫转移酶检测试剂盒,MPST试剂盒
小鼠D-多巴色素变位酶检测试剂盒,DDT试剂盒
小鼠Ⅶ型胶原检测试剂盒,COL7试剂盒
小鼠归巢关联细胞黏附分子检测试剂盒,HCAM试剂盒
小鼠白细胞弹性蛋白酶抑制因子检测试剂盒,LEI试剂盒
小鼠L1-细胞粘附分子检测试剂盒,L1CAM试剂盒
小鼠胸腺基质淋巴细胞生成素检测试剂盒,TSLP试剂盒
小鼠毒蕈碱型胆碱受体M2检测试剂盒,CHRM2试剂盒
