血管内皮生长因子A(VEGFA)多克隆抗体
Polyclonal Antibody to Vascular Endothelial Growth Factor A (VEGFA)
FOR IN VITRO AND RESEARCH USE ONLY, NOT FOR USE IN CLINICAL DIAGNOSTIC PROCEDURES!
Organism species Mus musculus (Mouse)
Product No. yb143Mu01
Clonality Polyclonal
Host Rabbit
Immunoglobulin Type IgG
Purification Affinity Chromatography
Applications WB, ICC, IHC-P, IHC-F, ELISA
Concentration 200ug/ml
UOM 100ug
Conjugate No Conjugate
IMMUNOGEN INFORMATION
Immunogen: Recombinant VEGFA (Ala27~Asn190) expressed in E.coli.
ANTIBODY SPECIFITY
The antibody is a rabbit polyclonal antibody raised against VEGFA. It has been selected for its ability to recognize VEGFA in immunohistochemical staining and western blotting.
APPLICATIONS
Western blotting: 1:100-400
Immunocytochemistry in formalin fixed cells: 1:100-500
Immunohistochemistry in formalin fixed frozen section: 1:100-500
Immunohistochemistry in paraffin section: 1:50-200
Enzyme-linked Immunosorbent Assay: 1:100-200
Optimal working dilutions must be determined by end user.
CONTENTS
Form & Buffer: Supplied as solution form in PBS, pH7.4,
containing 0.02% NaN3, 50% glycerol.
IHC Images
Used in DAB staining on fromalin fixed paraffin-embedded Kidney tissue
QUALITY CONTROL
Content: The quality control contains recombinant VEGFA (Ala27~Asn190) disposed in loading buffer.
Usage: 10uL per well when 3,3'-Diaminobenzidine(DAB) as the substrate.
5uL per well when used in enhanced chemilumescent (ECL).
Note: The quality control is specifically manufactured as the positive control. Not used for other purposes.
Loading Buffer: 100mM Tris(pH8.8), 2% SDS, 200mM NaCl, 50% glycerol, BPB 0.01%, NaN3 0.02%.
STORAGE
Store at 4oC for frequent use. Stored at -20oC to -80oC in a manual defrost freezer for one year without detectable loss of activity. Avoid repeated freeze-thaw cycles.
H9人胚胎干细胞培养方法
细胞百科之----口腔上皮细胞
钰博开学季 | 888元抢购细胞培养新装备
细胞学堂 | 直击细胞培养试剂四大疑难问题
小鼠氢/钾离子交换ATP酶β肽检测试剂盒,ATP4β试剂盒
小鼠丙酮酸羧化酶检测试剂盒,PC试剂盒
小鼠海藻糖酶检测试剂盒,TREH试剂盒
小鼠含铜胺氧化酶3检测试剂盒,AOC3试剂盒
小鼠补体成分4b检测试剂盒,C4b试剂盒
小鼠前蛋白转化酶枯草溶菌素9检测试剂盒,PCSK9试剂盒
小鼠双特异性磷酸酶1检测试剂盒,DUSP1试剂盒
小鼠巯基丙酮酸硫转移酶检测试剂盒,MPST试剂盒
小鼠D-多巴色素变位酶检测试剂盒,DDT试剂盒
小鼠Ⅶ型胶原检测试剂盒,COL7试剂盒
小鼠归巢关联细胞黏附分子检测试剂盒,HCAM试剂盒
小鼠白细胞弹性蛋白酶抑制因子检测试剂盒,LEI试剂盒
小鼠L1-细胞粘附分子检测试剂盒,L1CAM试剂盒
小鼠胸腺基质淋巴细胞生成素检测试剂盒,TSLP试剂盒
小鼠毒蕈碱型胆碱受体M2检测试剂盒,CHRM2试剂盒
