“Simplicity is the ultimate sophistication” Leonardo Da Vinci “至繁归于至简”-里昂那多达芬奇Imaging live cells over longer periods of time, to understand cellular behaviour and dynamic processes, is one of the biggest challenges facing researchers. 在过去的很长一段时间,通过对活细胞成像的方式来研究细胞的行为和动态过程一直都是世界难题。 With Livecyte™, the simple stepwise process means sophisticated long-term time lapse experiments can be set up in under 10 mins. 现在,通过 Livecyte™系统,仅需简单的操作就可以在10分钟以内设置出精密的长时间活细胞成像实验。 Less Time: Less Money: More Data 用更短的时间,花更少的钱,得到更多的数据 No extensive training requirements 无需大量的培训 Livecyte's intuitive user interface is designed for ease of use, providing immediate access to the system without the need for costly and time consuming training. Livecyte系统操作页面秉承的设计理念是直观,使用简单。用户无需付费或花大量的时间来学习如何使用系统,真正做到每个人都可以直接上手操作。 Complete and efficient workflows 完整并且高效的工作流程 Users are guided through each stage of the experiment. The simple Design-Acquire-Analyse functions direct each stage of the experiment, from well selection to image capture, reducing unproductive laboratory time. 用户在实验中每一步的操作,系统页面都会出现对应的提示引导操作。简单的 Design-Acquire-Analyse界面,从选择孔板到获取图像,时刻引导用户如何操作下一步,减少低效率时间的浪费。 No dedicated consumables 无需专门的耗材 Livecyte works with your standard laboratory consumables, requiring no specialist plates, labels or preparatory kits. Simply seed the cells, place on the microscope and start capturing high contrast, high resolution images. Livecyte完全适配于您目前的标准实验耗材,无需专门的孔板,标记或试剂盒。只需进行简单的铺细胞,将细胞放入显微成像系统,即可开始获取高对比度和高分辨率的图像。 96 well compatibility 96孔板的兼容性 Multiple parameters can be assessed and compared in a single experiment, for more efficient use of laboratory resources. 同一实验内多重参数可以被同时分析,提高实验效率。
Automated processing & analysis 自动化的运算和分析 Livecyte's Cell Analysis Toolbox™ software automatically generates a comprehensive range of outputs providing multi-parametric data to individual cell level, for more reliable and reproducible cell profiling. Livecyte的 Cell Analysis Toolbox™计算分析系统自动地计算出精确到单细胞层面的多参数综合信息,以此建立可信的可重复的细胞身份信息。
Livecyte - It Just Works!Livecyte – 就是它! The simple solution for sophisticated label-free live cell imaging 解决复杂的非标记活细胞成像的简单方法 See an example of the simple experimental set-up workflow in the short video below.
以下视频介绍了Livecyte实验设计的操作简易程度。 |
