QUV紫外光老化加速试验机是简单、可靠、易用的紫外老化试验机。世界各地使用的QUV紫外加速老化试验机数以万计,它是世界上使用广泛的紫外老化试验机。
QUV紫外光老化加速试验机使用特殊的荧光紫外灯管模拟阳光的照射,用冷凝湿度和水喷雾的方法模拟露水和雨水,真实地再现由阳光造成的材料损伤。损伤类型包括褪色、光泽消失、粉化、龟裂、开裂、模糊、起泡、脆化、强度减小和氧化。
QUV紫外光老化加速试验机代理罗中科技
测试标准列表如下:
AAMA 624
Voluntary Specification, Performance Requirements and Test Procedures for High Performance Organic Coatings on Fiber Reinforced Thermoset Profiles
This specification describes test procedures and performance requirements for high performance, organic, coatings applied to fiber reinforced thermoset profiles for windows, doors and similar products.
AAMA 624
纤维增强热固性型材上的高性能有机涂层的推荐规格、性能要求和测试程序
本规范描述了高性能有机涂料的测试程序和性能要求,这类涂料应用于纤维增强热固性型材(窗、门和类似的产品)。
AATCC TM186
Weather Resistance: UV Light and Moisture Exposure
This test method provides a procedure for the exposure of textile materials of all kinds, including coated fabrics and products made thereof, in a laboratory artificial weathering exposure apparatus employing fluorescent UV lamps as a light source and using condensing humidity and/ or water spray for wetting.
AATCC TM186
耐候性 紫外线和潮湿曝露测试
本测试方法提供了各类纺织品材料(包括涂层织物和由其制造的产品)曝露测试的程序。测试采用实验室人工老化曝露装置,用荧光紫外灯管作为光源,使用冷凝加湿和/或喷淋加湿。
ASTM C1257
Standard Test Method for Accelerated Weathering of Solvent-Release-Type Sealants
This test method includes two laboratory accelerated exposure procedures for predicting the effects of ultraviolet or ultraviolet/visible radiation, heat, and moisture on color, chalking, cracking, and adhesion of solvent-release sealants.
ASTM C1257
溶剂释放型密封剂加速老化的标准测试方法
该测试方法包括两个实验室加速暴露测试程序,用于预测紫外线或紫外线/可见光辐射、热量和湿气对溶剂释放型密封剂的颜色、粉化、开裂和附着力的影响。
ASTM C1442
Practice for Conducting Tests on Sealants Using Artificial Weathering Apparatus
This practice covers three types of laboratory weathering exposure procedures for evaluating the effect of actinic radiation, heat, and moisture on sealants.
ASTM C1442
使用人工老化设备对密封剂进行测试的方法
本测试方法包括三种实验室加速老化曝露程序,评估太阳光辐射、热和潮湿对密封剂的影响。
ASTM C1501
Standard Test Method for Color Stability of Building Construction Sealants as Determined by Laboratory Accelerated We
SFP火焰光度计的应用与介绍
呼吸阻力测试仪的应用与介绍
过滤性能测试设备:MFP 3000模块化过滤介质测试台
Q-SUN XE-1氙灯老化箱可以测试PUMA PCT-07标准
