零件号 | 中文描述 | |
Pump parts/泵零件 | ||
Agilent 1100 Power supply | 1100电源 | |
Agilent 1100 Pulse damper | 1100脉冲阻尼器 | |
G1310-66500 | Agilent 1100 Pump main board | 1100泵主板 |
G1310-69500 | Agilent 1100 Pump main board | 1100泵主板 |
G1311-66500 | Agilent 1100 Pump main board | 1100泵主板 |
G1311-66510 | Agilent 1100 Pump main board | 1100泵主板 |
G1311-67701 | Agilent 1100 MCGV | 1100MCGV多通道梯度阀 |
G1311-69701 | Agilent 1100 MCGV | 1100MCGV多通道梯度阀 |
G1311-60001 | Agilent 1100 Pump drive mechanism | 1100泵驱动机械结构 |
G1311-69001 | Agilent 1100 Pump drive mechanism | 1100泵驱动机械结构 |
G1311-69500 | Agilent 1100 Pump main board | 1100泵主板 |
G1311-69510 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-66510 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-69510 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-66520 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-69520 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-66530 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-69530 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-66540 | Agilent 1100 Pump main board | 1100泵主板 |
G1312-69540 | Agilent 1100 Pump main board | 1100泵主板 |
Autosampler parts自动进样器零件 | ||
G1313-60008 | Agilent 1100 sampling unit | 1100进样单元 |
G1313-60009 | Agilent 1100 Transport assembly | 1100传输组件 |
G1313-69029 | Agilent 1100 Transport assembly | 1100传输组件 |
G1313-66500 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1313-69500 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1313-66510 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1313-69510 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1313-66520 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1313-69520 | Agilent 1100 autosampler main board | 1100自动进样器主板 |
G1329-60009 | Agilent 1100 chiller A/S transport arm | 1100冷却自动进样传输臂 |
G1329-69029 | Agilent 1100 chiller A/S transport arm | 1100冷却自动进样传输臂 |
G1329-66500 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-69500 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-66510 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-69510 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-66520 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-69520 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-66530 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-69530 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-66540 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1329-69540 | Agilent 1100 chiller option autosampler board | 1100冷却自动进样器板 |
G1367-60029 | Agilent 1100 Wellplate transport arm | 1100微孔传输臂 |
G1367-69029 | Agilent 1100 Wellplate transport arm | 1100微孔传输臂 |
G1367-66500 | Agilent 1100 Wellplate main board | 1100微孔主板 |
G1367-69500 | Agilent 1100 Wellplate main board | 1100微孔主板 |
G1367-66510 | Agilent 1100 Wellplate main board | 1100微孔主板 |
G1367-69510 | Agilent 1100 Wellplate main board | 1100微孔主板 |
G1367-66520 | Agilent 1100 Wellplate main board | 1100微孔主板 |
G1367-69520 | Agilent 1100 Wellplate main board | 1100微孔主板 |
Controllers控制器 | ||
G1323A | Agilent 1100 controller | 1100控制器 |
G1323B | Agilent 1100 controller | 1100控制器 |
G4208-67001 | Agilent 1200 controller | 1200控制器 |
Detector Parts/检测器零件 | ||
G1314-60060 | Agilent 1100 VWD optics unit | 1100VWD光学单元 |
G1314-69060 | Agilent 1100 VWD optics unit | 1100VWD光学单元 |
G1314-66521 | Agilent 1100 VWD main board | 1100VWD主板 |
G1314-69521 | Agilent 1100 VWD main board | 1100VWD主板 |
G1314-66526 | Agilent 1100 VWD main board | 1100VWD主板 |
G1314-69526 | Agilent 1100 VWD main board | 1100VWD主板 |
G1315-60002 | Agilent 1100 MWD/DAD optics unit | 1100MWD/DAD光学单元 |
G1315-69002 | Agilent 1100 MWD/DAD optics unit | 1100MWD/DAD光学单元 |
G1315-60004 | Agilent 1100 MWD/DAD optics unit | 1100MWD/DAD光学单元 |
G1315-69004 | Agilent 1100 MWD/DAD optics unit | 1100MWD/DAD光学单元 |
G1315-66500 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-69500 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-66510 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-69510 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-66520 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-69520 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-66530 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-69530 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-66540 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1315-69540 | Agilent 1100 DAD DAM board | 1100DAD DAM板 |
G1365-66500 | Agilent 1100 MWD main board | 1100 MWD主板 |
G1365-69500 | Agilent 1100 MWD main board | 1100 MWD主板 |
G1365-66510 | Agilent 1100 MWD main board | 1100 MWD主板 |
G1365-69510 | Agilent 1100 MWD main board | 1100 MWD主板 |
G1365-66520 | Agilent 1100 MWD main board | 1100 MWD主板 |
G1365-69520 | Agilent 1100 MWD main board | 1100 MWD主板 |
安捷伦质谱仪维修 5975C
安捷伦 Agilent 7000 系列 GC/TQ 系统 维修
安捷伦6460 GCMS 维修
AB SCIEX 4000 维修现场 清洗维修保养
AB SCIEX QTRAP 6500+ LC-MS/MS 液质联用系统 租/售
SHIMADZU 岛津 LCMS-8050 + LC-30A 液质联用系统 租/售
AB SCIEX X500R QTOF 高分辨率液质联用系统
安捷伦 Agilent 6550 iFunnel Q-TOF LCMS
AB液质联用仪 SCIEX Triple Quad™ 7500 LC-MS/MS系统
二手 赛默飞 Corona Veo(RS) 电雾式检测器 CAD检测器
安捷伦 Agilent 1290 Infinity ll-6470 液质联用仪
二手岛津 GCMS-QP2020 NX 气相色谱质谱联用仪 HS-20 顶空进样器
二手 Agilent安捷伦1290 Infinity II 高效液相色谱仪
二手安捷伦 Agilent 7700 ICP-MS 电感耦合等离子质谱仪
二手岛津 LC-2030 C 3D PLUS 岛津液相色谱仪
岛津 QP2010 SE GCMS,GC-2010 Plus 带顶空采样器 HS-20
Beckman Coulter PA800 plus 高级毛细管电泳仪
二手 Agilent 7697A 顶空自动进样器
二手 Agilent 安捷伦 1200+6120 LCMS 单四极杆液质联用系统
