Wiley添加光谱并增强其光谱库收藏
2022年11月15日–研究和教育领域的全球领导者Wiley宣布更新其KnowItAll光谱库集合中的18个数据库,包括其红外、拉曼、NMR和质谱集合。
最突出的更新是在Wiley Registry订阅中增加了40000个GC-MS光谱。*著名的Wiley Registry是商业上最大的质谱库,拥有超过800000个高质量光谱,在环境、健康、法医学、毒理学、代谢组学等应用中进行光谱分析人员的关键资源。
光谱也被添加到拉曼、红外和Sigma NMR集合中,并且对Hummel 红外光谱数据库进行了显著增强。请参阅下表以获取最近更新的摘要。
Wiley的KnowItAll光谱库集合提供了超过200万个高质量光谱,包括红外、质谱、NMR、拉曼和UV-Vis。这些数据库对于光谱的解释、识别、验证和分类的分析实验室工作流程至关重要。这些藏品涵盖了广泛的应用领域,包括聚合物/材料、环境、法医学/毒理学、制药、国防/安全、生物技术、汽车/航空航天、食品/化妆品等。
了解更多有关Wiley Science Solutions公司光谱数据收集的信息:http://www.paastech.com/specana
*只有通过KnowItAll质谱库或Wiley Registry订阅才能独家访问附加补充数据。
当前KnowItAll数据库订阅服务器:如何更新到最新版本
如果您的KnowItAll Spectral Library订阅许可证处于活动状态,您可以随时访问许可订阅中可用的最新数据。如果未设置为自动更新数据库以充分利用订阅,请确保手动更新数据库。了解更多信息。
Nov 15, 2022 – Wiley, a global leader in research and education, announced updates to 18 of the databases in its KnowItAll Spectral Library collections from its IR, Raman, NMR, and MS collections.
The most prominent update is the addition of 40,000 GC-MS spectra to the Wiley Registry subscription.* The renowned Wiley Registry is the largest mass spectral library commercially available with over 800,000 high-quality spectra and is a critical resource for those performing spectral analysis across applications such as environmental, health, forensics, toxicology, metabolomics, and many more.
Spectra were also added to the Raman, IR, and Sigma NMR collections and significant enhancements were made to the Hummel IR collections. See table below for a summary of the recent updates made.
Wiley’s KnowItAll Spectral Library collections provide access to over 2 million high-quality spectra including IR, MS, NMR, Raman, and UV-Vis. These databases are critical to analytical laboratory workflows for the interpretation, identification, verification, and classification of spectra. The collections cover a wide range of applications including polymer/materials, environmental, forensics/toxicology, pharmaceutical, defense/security, biotech, automotive/aerospace, food/cosmetics, and more.
Learn more about our spectral data collections at Wiley Science Solutions: http://www.paastech.com/specana
*Exclusive access to the additional supplemental data is only available through the KnowItAll Mass Spectral Library or Wiley Registry subscription.
Current KnowItAll Database Subscribers: How to Update to the Latest Version
If your KnowItAll Spectral Library subscription license is active, you can always access the most recent data available in your licensed subscription. Ensure that you update your databases manually if you are not set up to automatically do so to take full advantage of your subscription. Learn More.
Below is a Summary of Recent Updates to Wiley's Spectral Database Collections
Database | Updates Made |
KnowItAll IR Spectral Library Collection | |
Hummel Databases
| New and enhanced chemical structures and refreshed metadata. |
| New and enhanced chemical structures. |
| Added 185 new spectral records. |
KnowItAll Raman Spectral Library Collection | |
| Added 123 new spectral records. |
| Minor updates were made. |
KnowItAll Mass Spectral Library Collection | |
| Added over 40,000 new spectral records.* Exclusive access to the additional supplemental data is only available through the KnowItAll Mass Spectral Library or Wiley Registry subscription. |
Sigma Aldrich Library of NMR Spectra Library | |
| Added 2,070 13 CNMR and 2,064 HNMR new spectral records. |
2024Discov-IR色谱-固态沉积红外光谱仪技术研讨会(台湾)
KnowItAll 2024更新内容
KnowItAll 2024新版本发布 - 具有新的多技术定量工具选项和光谱分析的许多其他进展
KnowItAll数据库更新-202301
光谱解析系统
萨特勒红外光谱数据库
KnowItAll分析版
KnowItAll 红外/拉曼光谱分析软件
KnowItAll拉曼光谱数据库
Wiley KnowItAll质谱库
派艾斯PORT IR便携式傅里叶红外化学物质鉴定仪
芬太尼类新精神活性物质红外光谱数据库
DiscovIR液相色谱-微沉积固态红外联用仪
DiscovIR-GC气相色谱-微沉积固态红外联用仪
MS Noise NRVP质谱隔音罩
ionBench BCH190NE78质谱工作台
ionBench LC4555色谱工作台
MS Noise DBL质谱隔音罩
布鲁克Bruker超轻元素微区X射线荧光成像光谱仪 M4 TORNADO PLUS
