作者:中科院西北生态环境资源研究所石玉兰、兰州大学生科院安黎哲
标题:Integrated regulation triggered by a cryophyte ω-3 desaturase gene confers multiple-stress tolerance in tobacco
主题:ω-3脂肪酸去饱和酶在植物胁迫耐受中的功能
期刊:Journal of Experimental Botany
影响因子:5.354
检测指标:Ca2+
英文摘要
ω-3 fatty acid desaturases (FADs) are thought to contribute to plant stress tolerance mainly through linolenic acid (C18:3)-induced membrane stabilization, but a comprehensive analysis of their roles in stress adaptation is lacking.
Here, we isolated a microsomal ω-3 FAD gene (CbFAD3) from a cryophyte (Chorispora bungeana) and elucidated its functions in stress tolerance. CbFAD3, exhibiting a high identity to Arabidopsis AtFAD3, was up-regulated by abiotic stresses. Its functionality was verified by heterogonous expression in yeast. Overexpression of CbFAD3 in tobacco constitutively increased C18:3 in both leaves and roots, which maintained the membrane fluidity, and enhanced plant tolerance to cold, drought, and salt stresses.
Notably, the constitutively increased C18:3 induced a sustained activation of plasma membrane Ca2+-ATPase, thereby, changing the stress induced Ca2+ signaling. The reactive oxygen species (ROS) scavenging system, which was positively correlated with the level of C18:3, was also activated in the transgenic lines.
Microarray analysis showed that CbFAD3-overexpressing plants increased the expression of stressresponsive genes, most of which are affected by C18:3, Ca2+, or ROS. Together, CbFAD3 confers tolerance to multiple stresses in tobacco through the C18:3-induced integrated regulation of membrane, Ca2+, ROS, and stress-responsive genes. This is in contrast with previous observations that simply attribute stress tolerance to membrane stabilization.
中文摘要(谷歌机翻)
ω-3脂肪酸去饱和酶(FADs)被认为主要通过亚麻酸(C18:3)诱导的膜稳定作用促进植物抗逆性,但缺乏对其在胁迫适应中的作用的综合分析。
在这里,我们从冷冻植物(Chorispora bungeana)中分离出微粒体ω-3 FAD基因(CbFAD3),并阐明其在胁迫耐受中的功能。表现出与拟南芥AtFAD3高度同一性的CbFAD3被非生物胁迫上调。其功能通过酵母中的异源表达来验证。烟草中CbFAD3的过量表达在叶和根中组成性地增加了C18:3,这保持了膜的流动性,并增强了植物对冷,干旱和盐胁迫的耐受性。
值得注意的是,组成型增加的C18:3诱导质膜Ca2+-ATPase的持续活化,从而改变应激诱导的Ca2+信号传导。与C18:3水平正相关的活性氧(ROS)清除系统也在转基因系中被激活。
微阵列分析显示过表达CbFAD3的植物增加了应激反应基因的表达,其中大多数受C18:3,Ca2+或ROS的影响。 CbFAD3一起通过C18:3诱导的膜,Ca2+,ROS和应激反应基因的整合调节赋予对烟草中多种胁迫的耐受性。这与先前的观察结果形成对比,之前的观察结果仅仅将压力耐受性归因于膜稳定。
Ca2+ fluxes in root tips treated with 15% PEG or 200 mM NaCl (n=10 ten-day-old seedling roots).
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
