期刊:JOURNAL OF AGRICULTURALAND FOOD CHEMISTRY
主题:低氮提升油菜氮利用率新机制
标题:Low Nitrogen Enhances Nitrogen Use Efficiency by Triggering NO3– Uptake and Its Long-Distance Translocation
影响因子:3.412
检测指标:NO3-、H+
作者:湖南农业大学张振华、吴智敏
英文摘要
Nitrogen is essential for plant growth andcrop productivity; however, nitrogen use e?ciency (NUE) decreases withincreasing N supply, resulting in a waste of resources. Molecular mechanismsunderlying low-nitrogen (LN)-mediated enhancement of NUE are not clear.
We used high-NUE Brassica napus genotype H(Xiangyou 15), low-NUE B. napus genotype L (814), and Arabidopsis mutant aux1to elucidate the mechanism underlying the changes in NUE under di?erent ratesof N fertilizer application. NUE of B. napus increased under LN, which enhancedN uptake ability by regulating root system architecture and plasma membraneH+-ATPase activity; AUX1 was involved in this process.
Additionally, BnNRT1.5 was upregulated andBnNRT1.8 was downregulated under LN, whereby more N was transferred to theshoot through enhanced N transport. Observed changes in photosynthesis under LNwere associated with N assimilation e?ciency. Our study provides new insightsinto the mechanisms of plant adaptation to the environment.
中文摘要(谷歌机翻)
氮对植物生长和作物生产力至关重要;然而,随着氮供应的增加,氮利用效率(NUE)降低,导致资源浪费。低氮(LN)介导的NUE增强的分子机制尚不清楚。
我们使用高NUE甘蓝型油菜基因型H(香优15),低NUE
B.napus基因型L(814)和拟南芥突变体aux1来阐明在不同氮肥施用量下NUE变化的机制。甘蓝型油菜NUE在LN下增加,通过调节根系结构和质膜H+ -ATPase活性提高N吸收能力; AUX1参与了这个过程。
另外,BnNRT1.5被上调并且BnNRT1.8在LN下被下调,由此通过增强的N转运将更多的N转移到芽。观察到的LN下光合作用的变化与N同化效率有关。我们的研究为植物适应环境的机制提供了新的见解。
Gas exchange, chlorophyll content, and photosynthetic N use in two contrasting B. napus genotypes for N use e?ciency under LN (1 mM NO3? N, black bars) or CK (15 mM NO3? N, white bars) conditions: (a) photosynthetic rate, (b) SPAD, (c) transpiration rate, and (d) photosynthetic N use e?ciency (PNUE). The bar height represents the mean, and error bars indicate standard deviation (n = 6). Di?erent letters on bars indicate signi?cant di?erences based on Tukey’s HSD (p < 0.05). The statistical analysis was performed on di?erent treatments within genotypes.
文章链接:
https://pubs.acs.org/doi/10.1021/acs.jafc.9b02491
本课题组往期NMT文章:
· V-ATPase and V-PPase at the Tonoplast Affect NO3- Content in Brassica napus by Controlling Distribution of NO3- Between the Cytoplasm and Vacuole
· Nitrogen Use Efficiency Is Mediated by Vacuolar Nitrate Sequestration Capacity in Roots of Brassica napus
· NRT1.1-related NH4+ toxicity is associated with balance between NH4+ uptake and assimilation
即日起,中关村NMT联盟统筹安排全国NMT测试服务,如需开展NMT相关实验,请联系联盟.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
