期刊:plant science
主题:氮素利用效率与镉耐受性的平衡
标题:Balance between nitrogen use efficiency and cadmium tolerance in Brassica napus and Arabidopsis thaliana
影响因子:3.785
检测指标: H+、Cd2+、NO3-流速
检测部位:根部液泡
H+、Cd2+、NO3-流实验处理方法:
4周龄拟南芥,20 μM CdCl2处理3天
21日龄油菜,100 μM CdCl2处理7天
H+、Cd2+、NO3-流实验测试液成份:
文献无
推荐测试液成份:
拟南芥根部液泡:0.002mM CdCl2,0.1 mM KNO3 , 600 mM mannitol, 0.05mM MES, pH 7.2
油菜根部液泡:0.01mM CdCl2,0.1 mM KNO3 , 600 mM mannitol, 0.05mM MES, pH 7.2
作者:湖南农业大学张振华、廖琼
英文摘要
The transmembrane transport of NO3? andCd2+ into plant cell vacuoles relies on the energy from their tonoplast protonpumps, V-ATPase and V-PPase. If the activity of these pumps is reduced, itresults in less NO3? and Cd2+ being transported into the vacuoles, whichcontributes to better nitrogen use efficiency (NUE) and lower Cd2+ tolerance inplants.
The physiological mechanisms that regulatethe balance between NUE and Cd2+ tolerance remain unknown. In our study, twoBrassica napus genotypes with differential NUEs, xiangyou 15 and 814, andAtclca-2 mutant and AtCAX4 over-expression line (AtCAX4-OE) of Arabidopsisthaliana, were used to investigate Cd2+ stress responses.
We found that the Brassica napus genotype,with higher NUE, was more sensitive to Cd2+ stress. The AtCAX4-OE mutant, withhigher Cd2+ vacuolar sequestration capacity (VSC), limited NO3? sequestrationinto root vacuoles and promoted NUE. Atclca-2 mutants, with decreased NO3? VSC,enhanced Cd2+ sequestration into root vacuoles and conferred greater Cd2+tolerance than the WT. This may be due to the competition between Cd2+ andNO3?in the vacuoles for the energy provided by V-ATPase and V-PPase. Regulating thebalance between Cd2+ and NO3? vacuolar accumulation by inhibiting the activityof CLCa transporter and increasing the activity of CAX4 transporter willsimultaneously enhance both the NUE and Cd2+ tolerance of Brassica napus,essential for improving its Cd2+ phytoremediation potential.
中文摘要(谷歌机翻)
NO3-和Cd2+跨膜转运到植物细胞液泡中依赖于其液泡膜质子泵,V-ATP酶和V-PPase的能量。如果这些泵的活性降低,则导致较少的NO3-和Cd2+被输送到液泡中,这有助于提高植物的氮利用效率(NUE)和降低Cd2+耐受性。
调节NUE和Cd2+耐受性之间平衡的生理机制尚不清楚。在我们的研究中,使用具有差异NUE,香优15和814的两种甘蓝型油菜基因型和拟南芥的Atclca-2突变体和AtCAX4过表达系(AtCAX4-OE)来研究Cd2+应激反应。
我们发现甘蓝型油菜基因型具有较高的NUE,对Cd2+胁迫更敏感。具有较高Cd2+液泡隔离能力(VSC)的AtCAX4-OE突变体限制NO3-隔离到根空泡中并促进NUE。具有降低的NO3-VSC的Atclca-2突变体增强了Cd2+隔离到根空泡中并且赋予比WT更大的Cd2+耐受性。这可能是由于V-ATP酶和V-PPase提供的能量在液泡中Cd2+和NO3-之间的竞争。通过抑制CLCa转运蛋白的活性和增加CAX4转运蛋白的活性来调节Cd2+和NO3-液泡积累之间的平衡将同时增强甘蓝型油菜的NUE和Cd2+耐受性,这对于改善其Cd2+植物修复潜力是必需的。
Fig. 2. The Arabidopsis thaliana vha-a2, vha-a3, and avp1 mutants were more sensitive to Cd2+ stress than the wild-type Col-0. (A) The phenotype and (B) the chlorophyll loss, in relation to the controls, of Col-0 and the vha-a2, vha-a3, and avp1 mutants grown for 4 weeks and then exposed to 20 μM CdCl2 for 3 days. Mean rates of (C) H+ ?uxes and (D) Cd2+ ?uxes during the ?rst 160 s of measurements within the root vacuoles.
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
