NMT是基因功能的活体检测技术,已被31位诺贝尔奖得主所在单位,及北大、清华、中科院使用。
2019年10月江苏师大NMT合作研究中心(测试中心)服务信息
期刊:Journal of Experimental botany
主题:钾离子和钙离子可渗透通道对H2O2的根区特异性敏感性决定了盐碱化二倍体和六倍体三叉戟的离子xxxxx
标题:Root-zone-specific sensitivity of K+-and Ca2+-permeable channels to H2O2 determines ion homeostasis in salinized diploid and hexaploid Ipomoea trifida
影响因子:5.354
检测指标:K+、H+、Ca2+、Na+流速
检测部位:甘薯
K+、H+、Ca2+瞬时:分生区(距离根尖500μm处),伸长(距尖端3毫米),成熟(尖端15毫米)
K+、Na++:分生组织区(距离尖端300-600μm)测量间隔为100μm),伸长区(1-3 mm)测量间隔为500μm的尖端和成熟区(距尖端10-15毫米,测量间隔为1毫米)
K+、H+、Ca2+、Na+流速流实验处理方法:
甘薯幼苗,150mM NaCl处理7d/150mM NaCl瞬时处理
K+、H+、Ca2+、Na+流速流实验测试液成份:
H+/K+/Ca2+瞬时:0.1 mM NaCl, 0.1 mM MgCl2,0.1 mM CaCl2, and 0.5 mM KCl at pH 5.7
K+:150 mM NaCl, 0.1 mM MgCl2, 0.1 mM CaCl2, and 0.5 mM KCl, pH 5.7
作者:江苏师范大学孙健、李宗芸
英文摘要
Polyploids generally possess superior K+/Na+ homeostasis under saline conditions compared with their diploid progenitors.
In this study, we identified the physiological mechanisms involved in
the ploidy-related mediation of K+/Na+ homeostasis in the roots of
diploid (2x) and hexaploid (6x; autohexaploid) Ipomoea trifida, which
is the closest relative of cultivated sweet potato. Results showed that
6x I. trifida retained more K+ and accumulated less Na+ in the root
and leaf tissues under salt stress than 2x I. trifida.
Compared with its 2x ancestor, 6x I. trifida efficiently prevents K+
efflux from the meristem root zone under salt stress through its plasma
membrane (PM) K+-permeable channels, which have low sensitivity to
H2O2. Moreover, 6x I. trifida efficiently excludes Na+ from the
elongation and mature root zones under salt stress because of the high
sensitivity of PM Ca2+-permeable channels to H2O2.
Our results suggest the root-zone-specific sensitivity to H2O2 of PM
K+- and Ca2+-permeable channels in the co-ordinated control of K+/Na+
homeostasis in salinized 2x and 6x I. trifida. This work provides new
insights into the improved maintenance of K+/Na+ homeostasis of
polyploids under salt stress.
中文摘要(谷歌机翻)
与二倍体祖细胞相比,多倍体在盐水条件下通常具有优越的K+ / Na+稳态。
在这项研究中,我们确定了与二倍体(2x)和六倍体(6x;自六倍体)Tripoda的根的K+/
Na+稳态的倍性相关介导有关的生理机制,这是栽培红薯的近亲。结果表明,与2x I. trifida相比,在盐胁迫下6x I.
trifida保留更多的K +并在根和叶组织中积累较少的Na+。
与2x祖先相比,6x裂叶线虫通过其对H2O2敏感性低的质膜(PM)K+渗透通道有效地防止了盐胁迫下分生组织根区的K+流出。此外,由于PM
Ca2+的可渗透通道对H2O2的敏感性高,因此6x I. trifida有效地将Na+从盐胁迫下的伸长和成熟根区中排除。
我们的结果表明,在盐渍化2x和6x盐粉虱的K+ / Na+动态平衡控制中,PM K+-和Ca2+渗透通道对H2O2的根区特异性敏感性。这项工作为改善盐胁迫下多倍体K+ / Na+稳态的维持提供了新的见解。
结果表明:在分生组织区中,观察到更高的K+流出量的是2x,在盐处理(约30分钟)期间,盐诱导的K+渗漏的平均速率高达4800 pmol cm-2 s-1(比6x高1.9倍)。但是,在伸长和成熟的根部区域观察到相反的趋势,其中6x比2x表现出更强烈的K+外排。
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
