NMT历史上的今天
2017年11月07日,首都师范大学印莉萍、谭松利用NMT在Traffic上发表了标题为TMD1 domain and CRAC motif determine the association and disassociation of MxIRT1 with detergent‐resistant membranes
的研究成果。
期刊:Traffic
主题:TMD1域和CRAC基序决定MxIRT1与耐去污剂膜的缔合和解离
标题:TMD1 domain and CRAC motif determine the association and disassociation of MxIRT1 with detergent‐resistant membranes
影响因子:4.133
检测指标:Cd2+流速
作者:首都师范大学印莉萍、谭松
英文摘要
Iron is essential for most living organisms. The
iron‐regulated transporter1 (IRT1) plays a major role in iron uptake in
roots, and its trafficking from endoplasmic reticulum (ER) to plasma
membrane (PM) is tightly coordinated with changes in iron environment.
However, studies on the IRT1 response are limited. Here, we report that
Malus xiaojinesis IRT1 (MxIRT1) associates with detergent‐resistant
membranes (DRMs, a biochemical counterpart of PM microdomains), whereas
the PM microdomains are known platforms for signal transduction in the
PM. Depending on the shift of MxIRT1 from microdomains to homogeneous
regions in PM, MxIRT1‐mediated iron absorption is activated by the
cholesterol recognition/interaction amino acid consensus (CRAC) motif of
MxIRT1.
MxIRT1 initially associates with DRMs in ER via its transmembrane
domain 1 (TMD1), and thus begins DRMs‐dependent intracellular
trafficking. Subsequently, MxIRT1 is sequestered in COPII vesicles via
the ER export signal sequence in MxIRT1.
These studies suggest that iron homeostasis is influenced by the CRAC
motif and TMD1 domain due to their determination of MxIRT1‐DRMs
association.
中文摘要(谷歌机翻)
铁对大多数生物都是必不可少的。铁调节转运蛋白1(IRT1)在根部吸收铁中起主要作用,其从内质网(ER)到质膜(PM)的运输与铁环境的变化紧密相关。
但是,有关IRT1反应的研究有限。在这里,我们报告说,小金海棠IRT1(MxIRT1)与耐去污剂的膜(DRM,PM微域的生化对应物)相关,而PM微域是PM中信号转导的已知平台。取决于MxIRT1从PM的微区到均质区的转移,MxIRT1介导的铁吸收被MxIRT1的胆固醇识别/相互作用氨基酸共有(CRAC)基序激活。
MxIRT1最初通过其跨膜结构域1(TMD1)与ER中的DRM结合,从而开始依赖DRM的细胞内运输。随后,通过MxIRT1中的ER出口信号序列将MxIRT1隔离在COPII囊泡中。
这些研究表明,由于铁的动态平衡决定了MxIRT1-DRM的相关性,因此受CRAC基序和TMD1域的影响。
G) Average Cd2+flux in the different transgenic Arabidopsis root hairs in 7-minute incubation with 0.05 mM CdCl2 measured by Non-invasion Micro-test Technology. The bars represent the means standard errors of 3 independent analyses (n = 3). Significant differences were determined by
Student’s t test. *P < 0.05, **P < 0.01
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
