NMT是基因功能的活体检测技术,已被103位诺贝尔奖得主所在单位,及北大、清华、中科院使用。
NMT历史上的今天
2017年01月06日,北京林业大学陈少良、张玉红用NMT在Frontiers in Plant Science上发表了标题为Paxillus involutus-Facilitated Cd2+Influx through Plasma Membrane Ca2+-Permeable Channels Is Stimulated by H2O2 and H+-ATPase in Ectomycorrhizal Populus × canescens under Cadmium Stress的研究成果。
期刊:Frontiers in Plant Science
主题:Paxillus involutus促进Cd2+吸收机制
标题:Paxillus involutus-Facilitated Cd2+ Influx through Plasma Membrane Ca2+-Permeable Channels Is Stimulated by H2O2 and H+-ATPase in Ectomycorrhizal Populus × canescens under Cadmium Stress
影响因子:4.495
检测指标:H+、Ca2+、Cd2+、H2O2流速
作者:北京林业大学陈少良、张玉红
英文摘要
Using a Non-invasive Micro-test Technique, flux
profiles of Cd2+, Ca2+, and H+ were investigated in axenically grown
cultures of two strains of Paxillus involutus (MAJ and NAU),
ectomycorrhizae formed by these fungi with the woody
Cd2+-hyperaccumulator, Populus × canescens, and non-mycorrhizal (NM)
roots.
The influx of Cd2+ increased in fungal mycelia, NM and ectomycorrhizal
(EM) roots upon a 40-min shock, after short-term (ST, 24 h), or
long-term (LT, 7 days) exposure to a hydroponic environment of 50 μM
CdCl2. Cd2+ treatments (shock, ST, and LT) decreased Ca2+ influx in NM
and EM roots but led to an enhanced influx of Ca2+ in axenically grown
EM cultures of the two P. involutus isolates.
The susceptibility of Cd2+ flux to typical Ca2+ channel blockers
(LaCl3, GdCl3, verapamil, and TEA) in fungal mycelia and poplar roots
indicated that the Cd2+ entry occurred mainly through Ca2+-permeable
channels in the plasma membrane (PM). Cd2+ treatment resulted in H2O2
production. H2O2 exposure accelerated the entry of Cd2+ and Ca2+ in NM
and EM roots. Cd2+ further stimulated H+ pumping activity benefiting NM
and EM roots to maintain an acidic environment, which favored the
entry of Cd2+ across the PM.
A scavenger of reactive oxygen species, DMTU, and an inhibitor of PM
H+-ATPase, orthovanadate, decreased Ca2+ and Cd2+ influx in NM and EM
roots, suggesting that the entry of Cd2+ through Ca2+-permeable
channels is stimulated by H2O2 and H+ pumps. Compared to NM roots, EM
roots exhibited higher Cd2+-fluxes under shock, ST, and LT Cd2+
treatments.
We conclude that ectomycorrhizal P. × canescens roots retained a
pronounced H2O2 production and a high H+-pumping activity, which
activated PM Ca2+ channels and thus facilitated a high influx of Cd2+
under Cd2+ stress.
中文摘要(谷歌机翻)
使用非损伤微测技术,研究了两株渐渐出现的新孢子虫(MAJ和NAU)的无性培养中Cd2+,Ca2+和H+的通量分布,这是由这些真菌与木质的Cd2+-超蓄积剂,胡杨形成的外生菌根 ×canescens和非菌根(NM)根。
短期(ST,24
h)或长期(LT,7天)暴露于水培环境的40分钟休克后,真菌菌丝体,NM和根外菌根(EM)根中Cd2+的流入增加。50μM氯化镉。Cd2+处理(电击,ST和LT)减少了NM和EM根中的Ca2+流入,但导致了两个渐近线对虾分离株的无性生长EM培养物中Ca2+的流入增加。
Cd2+通量对真菌菌丝体和杨树根中典型的Ca2+通道阻滞剂(LaCl3,GdCl3,维拉帕米和TEA)的敏感性表明,Cd2+进入主要通过质膜(PM)中的Ca2+渗透通道发生。Cd2+处理导致产生H2O2。H2O2暴露加速了NM和EM根中Cd2+和Ca2+的进入。Cd2+进一步刺激了H
+的泵送活性,有利于NM和EM根系维持酸性环境,这有利于Cd2+跨PM进入。
活性氧清除剂DMTU和PM H+ -ATPase的抑制剂原钒酸盐减少了NM和EM根中Ca2+和Cd2+的内流,这表明H2O2和H+泵刺激了Cd2+通过Ca2+渗透性通道的进入。与NM根相比,EM根在电击,ST和LT Cd2+处理下表现出更高的Cd2+通量。
我们得出的结论是,外生根茎假单胞菌根保留了明显的H2O2产生和高H+泵送活性,从而激活了PM Ca2+通道,从而促进了Cd2+胁迫下Cd2+的大量涌入。
FIGURE 1 | Effects of CdCl2 on transient kinetics of Cd2+, Ca2+, and H+ in Populus × canescens roots and Paxillus involutus strains MAJ and NAU. Cd2+ (A), Ca2+ (B), and H+ (C) kinetics were recorded before and after the required amount of 50 μM CdCl2was introduced
EP南农沈文飚:NMT发现H2S可提升CH4抑制紫花苜蓿吸Cd效果
农科院烟草所:NMT发现与红花烟草相比黄花烟草根系吸镉速率更大推测其具备土壤修复潜力
Sci Total Environ西南科大:NMT发现高Cu低Fe可减少水稻吸Cd但高Cu增加了籽粒Cd浓度
JIPB江苏师大朱明库、李宗芸:NMT发现SlSTE1通过ABA依赖的信号途径清除ROS提高K/Na比促番茄耐盐
