产品说明书
开机前请仔细阅读本说明书,若有疑问请及时与售后联系。建议您次使用少量样品进行实验,并妥善保管此说明书以备不时之需。
Please read this instruction carefully before starting, if you have any questions, please contact with the company in time. The first time you use this equipment, please use a small amount of sample for experiment, and properly keep this instruction for a rainy day.
8000Y主要适用于实验室对液状物料直接转化为微量粉末,无需在干燥前对物料进行过滤、浓缩和粉碎,对所有溶液如乳浊液、悬浮液具有广谱适用性。
8000Y This Equipment is mainly suitable for laboratory for changing liquid material directly into micro powder, without filtration, concentration and smash before drying, the supplies for all solution is a broad applicability, such as emulsion, suspending liquid。
一、适用范围Scope Of Application
本机主要适用于实验室对液状物料直接转化为微量粉末,无需在干燥前对物料进行过滤、浓缩和粉碎,对所有溶液如乳浊液、悬浮液具有广谱适用性。
二、随机组件Random Component
序号serial number名称name数量number
1玻璃干燥室Glass kiln1
2玻璃旋风分离器Glass cyclone separator1
3玻璃样品收集瓶glass sample collection bottle 500ML1
4玻璃样品收集管The glass sample collection tube1
5输料硅胶管Transporting the silicone tube 6mm1.5m
6喷雾枪spray pistol1
7卡箍clamp(LY12)黑色black1
三、安装说明Installation Instructions
a)干燥室的安装
用双手将干燥室托住然后插入干燥室固定托板上(置于白色PTFE垫块上),锁紧把手即可。
The installation of the Glass kiln :
Prop up the Glass kiln and then inserted into the fixed plate (PTFE in white on the block) , and lock the handle。
b)旋风分离器的安装
将旋风分离器紧缩螺母、密封圈及不锈钢垫片套入旋风分离器的出风管上,然后一起插入设备出风管中,调节干燥室出风口与旋风分离器进风口的位置,使两个口平直对齐,用卡箍将两个口连接起来,Z后紧缩旋风分离器紧缩螺母。
The installation of cyclone separator:
Fit the cyclone separator nut, seal ring and stainless steel gasket into the air outlet of cyclone separator, and then inserted into the air outlet of device, adjust the position of the air outlet of the Glass kiln and the inlet of the cyclone separator, make two mouth straight alignment, by connecting two mouth clamp, at last tightening nut tightening cyclone separator
c)用螺纹连接器将集料瓶和旋风分离器连接起来
Connect the aggregate bottle to the cyclone separator with threaded connector
d)用螺纹连接器将集料管和干燥室连接起来
Connect the aggregate tube to the Glass kiln with threaded connector
e)将喷雾腔安装到设备上,连接4mm气管(通针用)和6mm蓝色气管(喷雾用)
Connect the spray chamber into the device, and then connect 4 mm trachea (using for needle) to 6 mm blue trachea (using for spray)
f)安装食品级硅胶管至蠕动泵上,并插入喷雾腔进料口
Install the food-grade silicone tube to the peristaltic pump, and insert the inlet of the spray chamber
注意:所有玻璃器皿都为易碎品,安装和清洗时注意小心轻放,确认所有的部件都已安装就位后再上电操作。
Note: all glassware is fragile, handle with care when installation andr confirm all the components are installed in place before the electric operation。
四、操作说明Operating Instructions
1开机,显示如下界面,请选择中文或英文,点击进入系统
Power On,and the screen displays as the following。Please select Chinese or English,and click it to enter the system
为什么越来越多人选择使用短程分子蒸馏仪?
氮吹仪的用途及使用氮吹仪的四大优势
做植物生长培养用光照培养箱还是用人工气候箱好?
摇床的选分过程和工作原理
大容量低速离心机CHDD6A
氢空一体机发生器AYAN-NH500
低温冷冻离心机TGL-20M-II高低速离心机
12位全自动氮吹仪CYNS-12G
PSA变压吸附制氮机AYAN-40LB氮气发生器
台式恒温摇床TS-100C气浴振荡器
单双层摇瓶机CHYP-3111多段振荡频率
自动固相萃取仪CYCQ-12B智能SPE萃取装置
高温油浴振荡器CHYZ-B回旋摇床
台式光照摇床CHNS-110GZ低温振荡器
自动脱帽离心机TD5B
立式单门恒温摇床NS-2102C低温振荡器
水平振荡器CHSZD-10土壤废弃物震荡
真空离心浓缩仪CHLXZ-1A
全自动旋转振荡器CHXZ-2000*4分液漏斗翻转振荡
