本实验成果发布于EGU General Assembly 2023
The relevant paper was published in EGU General Assembly 2023
HT1800水汽开路分析仪Open-path Hygrometer
引言
水汽通量对于干旱监测和灌溉管理至关重要。它也是环境评估和生态系统建模的关键参数。
我们之前介绍了一种基于可调谐二极管激光器(TDLAS)的开路水汽分析仪(HT1800,宁波海尔欣光电科技有限公司),适用于涡动相关(EC)法测量水汽通量。
考虑到EC测量的光谱效应校正,我们准备了两台HT1800水汽分析仪进行现场实验。其中一台配备了近1392纳米的红外激光器,另一台配备了近1877纳米的激光器。
Introduction
Water vapor flux is essential for drought monitoring and irrigation management. It is also a key parameter for environmental assessment and ecosystem modeling.
We have earlier presented a TDLAS-based open-path water vapor analyzer (HT1800, HealthyPhoton Co., Ltd.), which is suitable for eddy covariance (EC) measurement of water vapor flux.
Considering spectroscopic effect correction for EC measurement, we prepared two HT1800 water vapor analyzers for field experiments. One is equipped with an infrared laser operating near 1392 nm, and the other near 1877 nm.
激光源和吸收线选择
激光源采用垂直腔面发射激光器(VCSEL),为一种功耗低、性价比高的光源。
1392纳米吸收线:TDLAS技术用于水汽检测中最常用的波长之一。
1877纳米吸收线:仿真和实验结果均发现其吸收线形变化较小,与温度的依赖关系较弱。
Laser source and absorption line selection
Vertical cavity surface emitting laser (VCSEL): low-power consumption and cost-effective light source
1392nm: one of the most used for TDLAS detection of water vapor
1877nm: found to have less temperature-dependent absorption lineshape variations
现场部署
地点:中国苏州市农业科学院(31°27'09.205''N,120°25'33.222‘’E)
时期1(图a):
时间:2022年5月7日至16日
风速仪:METEK© u-Sonic3 Cage MP
分析仪1:HT1800(1877纳米)
分析仪2:LI-COR© LI-7500RS
时期2(图b):
时间:2022年9月10日至10月5日
风速仪:Campbell© CSAT-3
分析仪1:HT1800(1392纳米)
分析仪2:Campbell© EC150
Field deployment
Site: Suzhou Academy of Agricultural Sciences of China. (31°27'09.205''N, 120°25'33.222‘’E)
Period 1 (figure a):
Time: May 7−16, 2022
Anemometer: METEK© u-Sonic3 Cage MP
Analyzer 1: HT1800 (1877nm)
Analyzer 2: LI-COR© LI-7500RS
Period 2 (figure b):
Time: September 10−October 5, 2022
Anemometer: Campbell© CSAT-3
Analyzer 1: HT1800 (1392nm)
Analyzer 2: Campbell© EC150
结论
我们通过现场部署调查了HT1800在测量水汽通量方面的性能。与另外两台商用分析仪的比较结果表明高度一致性。
采用1392纳米激光源的分析仪由于温度漂移而需要更高的光谱学校正率。然而,经校正后的数据与成熟分析仪的测量结果高度一致。
考虑到其便捷性,本研究证明了基于可调谐二极管激光器的1392纳米激光分析仪可以作为一种经济实惠的解决方案,用于精确测量水汽通量。
Conclusions
We investigated the HT1800 performance of measuring water vapor flux through field deployment. The comparisons with another two commercial analyzers showed high consistency.
The analyzer with a 1392nm laser source leads to a higher spectroscopic correction rate due to temperature drift. However, the corrected data showed a high degree of agreement with the measurements from a mature analyzer.
Considering its convenient availability, this work demonstrated that a TDLAS-based analyzer with a 1392nm laser could be used as a cost-effective solution to measure water vapor flux precisely.
参考文献:
Ting-Jung Lin, Kai Wang, Yin Wang, Zhimei Liu, Xiaojie Zhen, Xiaohua Zhang, Li Huang, Jingting Zhang, and Xunhua Zheng, “Measuring evapotranspiration fluxes using a tunable diode laser-based open-path water vapor analyzer,” EGU General Assembly 2023, EGU23-4030, 2023.
海尔欣氨气开路分析仪精确检测氨气,助力环保行动
HT8600P大气甲烷激光开路分析仪应对气候危机与健康
十周年视觉焕新:上位机全新体验,赋能智慧气体分析
零碳目标的科技助力者——“创新100”访宁波海尔欣光电科技有限公司
水汽开路分析仪HT1800昕甬智测
海尔欣HPLIA Plus外同步信号调制解调锁相放大器
高速碲镉汞(MCT)制冷型光电探测器HFPD-M-B海尔欣
全功能迷你量子级联激光发射头QC-Qube&trade海尔欣
大电流量子级联激光发射头QC-Qube Plus海尔欣
海尔欣QC-2000大电流量子级联激光屏显驱动器
半导体激光器屏显驱动器DFB-2000海尔欣
海尔欣HPPD系列非制冷型光电探测器
海尔欣HPHCH高温Herriott气体吸收池
HHL封装量子级联激光器 海尔欣 HPQCL-H HHL
标准量子级联激光发射头HPQCL-Q&trade海尔欣
QCL专用低噪声电流源及温控集成驱动 海尔欣
长光程气体吸收池(A/B系列)HPHC系列 Herriott海尔欣
微型双通道调制解调锁相放大器HPLIA海尔欣
海尔欣QC750-Touch™ 量子级联激光屏显驱动器
