本实验成果发布于IEEE SmartIoT 2023,国际智能物联网会议
The relevant paper was published in 2023 IEEE International Conference on Smart Internet of Things.
引言
偏远地区的无线传输资源有限,卫星通信则不受此限制。然而现有民用的卫星通信带宽具有局限性。该研究项目将实测数据经过压缩,最大化利用北斗短报文有限的字符数,并且尝试了加密算法,保证了碳监测数据的安全性。
Introduction
Wireless transmission resources in remote areas are limited, whereas satellite communication is not subject to such constraints. However, existing civilian satellite communication bandwidth has limitations. This research project compresses measured data, maximizing the use of the limited character count in Beidou short messages, and explores encryption algorithms to the security of carbon monitoring data.
实验:通信成功率
定义:数据延迟在1分钟内被定义为成功。
地点:宁波,中国
实验一:半暴露平台 通信成功率:82.5%
实验二:开放空间 通信成功率:92%
Experiments: communication successful rate
Definition: data delay within 1 min is defined as successful
Test site: Ningbo China (29°47'53''N, 121°33'46''E)
Experiment 1:Semi-exposed platform
Success rate: 82.5%
Experiment 2:Open space
success rate: 92%
结论
(1) 系统功耗
HT8850:100瓦
通信:每次传输峰值17.5瓦,持续时间<0.3秒,几乎不影响电池寿命。
(2) 最终实现了两种传输模式
第一种为单一用户模式,用户拥有自己的北斗接收模块,经过处理后的数据由树莓派实现灵活性高的数据获取。
第二种模式支持北斗数据上云,多个拥有权限的用户能够透过人性化的网页界面,从云端获取实时数据。
Conclusions
1. System power
HT8850: 100W
Communication: peak 17.5W for <0.3 secons duration per transmission, barely influencing the battery life
2. Two transmission modes were ultimately implemented
The first is a single-user mode, where each user has their own Beidou receiving module, and the processed data is obtained with high flexibility through a Raspberry Pi.
The second mode supports uploading Beidou data to the cloud, where multiple authorized users can access real-time data via a user-friendly web interface.
十年磨一剑,迈向低碳未来:HT8800系列更迭路
昕甬智测创始人十周年访谈:十年匠心,智慧与科技共筑绿色未来
持续高温,延期开学有必要吗?
涡动相关(EC)法是NH3/N2O通量原位无扰动高频观测的最优方法
水汽开路分析仪HT1800昕甬智测
海尔欣HPLIA Plus外同步信号调制解调锁相放大器
高速碲镉汞(MCT)制冷型光电探测器HFPD-M-B海尔欣
全功能迷你量子级联激光发射头QC-Qube&trade海尔欣
大电流量子级联激光发射头QC-Qube Plus海尔欣
海尔欣QC-2000大电流量子级联激光屏显驱动器
半导体激光器屏显驱动器DFB-2000海尔欣
海尔欣HPPD系列非制冷型光电探测器
海尔欣HPHCH高温Herriott气体吸收池
HHL封装量子级联激光器 海尔欣 HPQCL-H HHL
标准量子级联激光发射头HPQCL-Q&trade海尔欣
QCL专用低噪声电流源及温控集成驱动 海尔欣
长光程气体吸收池(A/B系列)HPHC系列 Herriott海尔欣
微型双通道调制解调锁相放大器HPLIA海尔欣
海尔欣QC750-Touch™ 量子级联激光屏显驱动器
