美国GMW-AKM_2011_Sensors_PG_GMW
2019-08-06 09:38  下载量:1
资料下载
A Hall Element is a magneto-electric transducer which utilizes the Hall Effect to measure or sense a magnetic field perpendicular to the Element. AKM Hall Elements typically have 4 pins, 2 input pins and 2 output pins, and can be driven by either a voltage or a current source. The output is a Hall voltage that is proportional to the magnetic field. The output from a Hall Element is analog and typically requires additional amplification. AKM uses four different semiconductor materials in its Hall Elements. These different materials represent AKM’s 4 different series of part numbers. The different materials provide different performance characteristics (magnetic sensitivity represented by electron mobility and band gap, operating voltage, temperature sensitivity, etc.) allowing the design engineer to choose the best solution for the particular application.
资料下载
文献贡献者
相关资料 更多
当前位置: 筱晓光子 资料 美国GMW-AKM_2011_Sensors_PG_GMW
