资料下载Scanning Electron Microscopy (SEM) is one of the most versatile instruments for the examination of the surface topography and composition of the sample. The surface images result from the interaction of a focused electron beam with atoms in the sample, which can achieve < 1 nm resolution. Signals generated during the interaction include secondary electrons (SE), back-scattered electrons (BSE), characteristic X-ray and cathodoluminescence, absorbed current, and transmitted electrons. SE is the most standard signal that SEM detects. It has low energies, which leads to a higher resolution. BSE occurs in deeper places within the sample and strongly relates to the atomic number. It is very often used for composition analysis along with characteristic X-ray spectra. Many SEM measurements are conducted when the sample stage is cooled down to cryogenic temperatures based on different sample properties.
我司在甘肃某大学成功进行了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环低温恒温器的安装工作
简介:近日,我司在甘肃某大学成功进行了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环低温恒温器的安装工作。 美国ARS(ADVANCED RESEARCH SYSTEMS)是一家世界级低温系统厂商,创立于1986年,主要产品为低温恒温器和低温探针台,ARS(ADVANCED RESEARCH SYSTEMS)致力于为科研工作者提供1.5-800K低温解决方案。 美国ARS(ADVANCED RESEARCH SYSTEMS)低温恒温器种类繁多,广泛应用于各类光电磁测试,如(显微)光致发光,显微拉曼,显微-FTIR,量子点,磁光克尔效应(MOKE) ,金刚石压砧,热电磁化率测试,荧光,霍尔等等。 产品主要包括液氮储槽型低温恒温器,液氦/液氮连续流型低温恒温器,标准闭循环无液氦低温恒温器,超精细超稳超低振动低温恒温器,顶端装载型闭循环低温恒温器。 各类低温恒温器都可升级为超高真空(UHV)刀口法兰结构,获得10-11torr极限真空。其中液氦/液氮型低温恒温器振动为埃米级别,超精细超稳超低振动低温恒温器振动仅为3-5nm。
我司在浙江某大学成功进行了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环低温恒温器的安装
简介:美国ARS(ADVANCED RESEARCH SYSTEMS)是一家世界级低温系统厂商,创立于1986年,主要产品为低温恒温器和低温探针台,ARS(ADVANCED RESEARCH SYSTEMS)致力于为科研工作者提供1.5-800K低温解决方案。 美国ARS(ADVANCED RESEARCH SYSTEMS)低温恒温器种类繁多,广泛应用于各类光电磁测试,如(显微)光致发光,显微拉曼,显微-FTIR,量子点,磁光克尔效应(MOKE) ,金刚石压砧,热电磁化率测试,荧光,霍尔等等。 产品主要包括液氮储槽型低温恒温器,液氦/液氮连续流型低温恒温器,标准闭循环无液氦低温恒温器,超精细超稳超低振动低温恒温器,顶端装载型闭循环低温恒温器。 各类低温恒温器都可升级为超高真空(UHV)刀口法兰结构,获得10-11torr极限真空。其中液氦/液氮型低温恒温器振动为埃米级别,超精细超稳超低振动低温恒温器振动仅为3-5nm,非常适合对振动要求苛刻的显微拉曼、荧光,激光等常用的显微光谱测试。顶端装载(Top-loading)结构可实现不停机快速换样,非常适合大批量样品的测试。
我司在北京某大学成功进行了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环超导磁体探针台的安装工作
简介:近日,我司在北京某大学成功完成了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环超导磁体探针台的安装工作。 美国ARS(ADVANCED RESEARCH SYSTEMS)是一家世界级低温系统厂商,创立于1986年,主要产品为低温恒温器和低温探针台,ARS(ADVANCED RESEARCH SYSTEMS)致力于为科研工作者提供1.5-800K低温解决方案。 美国ARS低温探针台种类繁多,用于样品的非破坏性检测,测试灵活,广泛应用于直流(DC),射频(RF),MEMS, 纳米电子,超导性,纳米电路的光电特性,量子点和量子线等。 产品主要包括液氦/液氮连续流型低温探针台,闭循环无液氦低温探针台,超稳型纳米科技低温探针台,电磁铁低温探针台,超导磁体低温探针台。各类探针台都可升级为超高真空(UHV)刀口法兰结构,获得10-11torr极限真空,其中超稳型纳米科技低温探针台样品处振动只有10nm,非常适合对振动要求苛刻的应用,超导磁体探针台样品处最高磁场可达4T。
我司在上海某大学成功进行了美国ARS(ADVANCED RESEARCH SYSTEMS)闭循环低温恒温器的安装
简介:美国ARS(ADVANCED RESEARCH SYSTEMS)是一家世界级低温系统厂商,创立于1986年,主要产品为低温恒温器和低温探针台,ARS(ADVANCED RESEARCH SYSTEMS)致力于为科研工作者提供1.5-800K低温解决方案。 美国ARS(ADVANCED RESEARCH SYSTEMS)低温恒温器种类繁多,广泛应用于各类光电磁测试,如(显微)光致发光,显微拉曼,显微-FTIR,量子点,磁光克尔效应(MOKE) ,金刚石压砧,热电磁化率测试,荧光,霍尔等等。 产品主要包括液氮储槽型低温恒温器,液氦/液氮连续流型低温恒温器,标准闭循环无液氦低温恒温器,超精细超稳超低振动低温恒温器,顶端装载型闭循环低温恒温器。 各类低温恒温器都可升级为超高真空(UHV)刀口法兰结构,获得10-11torr极限真空。其中液氦/液氮型低温恒温器振动为埃米级别,超精细超稳超低振动低温恒温器振动仅为3-5nm,非常适合对振动要求苛刻的显微拉曼、荧光,激光等常用的显微光谱测试。 顶端装载(Top-loading)结构可实现不停机快速换样,非常适合大批量样品的测试。
OPTI-MAGNETO磁光超导低温系统
DRYICE1K 超低温系统
美国ARS LT3-OM显微型低温恒温器
美国ARS LT3液氦流型低温恒温器
美国IRLabs红外实验室Bolometer 辐射热测量计系统
美国ARS超稳超低振动低温探针台‐PS‐NS‐10‐4
美国ARS低温闭循环真空探针台-PSF-10-4
美国ARS标准光学型闭循环低温恒温器X-1AL
美国ARS超稳无液氦低温恒温器-udrift
美国ARS超低振动超精细闭循环低温恒温器X-20
美国ARS顶端装载型闭循环非光学低温恒温器X-19-NO
美国ARS显微型超低振动超精细闭循环低温恒温器-X20-OM
美国ARS液氦型连续流低温恒温器LT4
美国ARS-UHV超低振动超精细闭循环恒温器 X-20B
美国ARS UHV显微型连续流低温恒温器 LT3B-OM
