Data No.RR09-07098 KEM Application Note No.DAZ-07116Density Measurement Kyoto Electronics Manufacturing Co., Ltd. Density of 2-propanol (IPA) -Measuring instrument- Main unit:DA-520 Density meter Option: Auto clean unit DCU-551N -Solvent- Rinse -1: water Rinse-2: acetone Rinse-2: acetone Summary- Checked reproducibility of density measurement of IPA DA-520+DCU-551N, and obtained goodstandard deviation of 0.00001g/cm°(n=5). -Measurement method- 1. Measurement temperature was set to 20°C. 2. Calibration was performed with air and water. 3. The samples were put in vials and covered with wrapping film till measurement started.4. Pressed [Meas.] key for measurement of density of the sample liquid. -Concentration conversion, temperature compensation formula- -Ambient condition- Ambient: 23.5℃ Humidity: 59% Weather: Fine -Literature- 上海旭风科学仪器有限公司 上海市闸北区万荣路388弄17号904室 200072 Http://www. shxf17. com Method No. : 0 Method Name : IPA Temperature : 20.00℃ Stability 1 Limit Time : 600 s Sequence : On Sampling Seq. : Auto Samp. Limit 0 s O.S. Rate 150% Drain Seq. Auto Drain Rate : 200% Rinse-1 Seq.: Set Rinse-1 Time: 10 s Rinse-2 Seq. : Set Rinse-2 Time: 10s Purge Seq. : Auto Cell Test : Off Calib. Air&Water ***Result*** Sample No. 01-01 Meas. Temp.: 20.00 ℃ Period T : 1035843d [g/cm3] 0.78512 Meas. Time:00:02:02 ***Result*** Sample No. 01-02 Meas. Temp. : 20.00℃ Period T 1035838d [g/cm3] : 0.78510 Meas. Time : 00:01:51 ***Result*** Sample No. 01-03 Meas. Temp.: 20.00℃ Period T 1035839 d [g/cm3] 0.78510 Meas. Time :00:02:04 -Measurement results- Run Data (g/cm 1 0.78512 2 0.78510 3 0.78510 45 0.78511 0.78512 Statistics Density Mean (g/cm)SD (g/cm)RSD (%) 0.785110.00001 0.00127 -Comment- Attention must be paid to evaporation of IPA. Tel: Fax: 周峰 zhou-fengcom
关闭产品配置单
上海旭风科学仪器有限公司为您提供《全自动密度计_测定异丙醇(IPA)的密度》,该方案主要用于其他中null检测,参考标准《暂无》,《全自动密度计_测定异丙醇(IPA)的密度》用到的仪器有null。
