Data No.LG38-08338 No.EKVJ-08362上海市漕溪路222号航天大厦北楼902室网址: http://www.kyoto-kem.net.cn KEM Application Note No.EKVJ-08362Volumetric Karl-Fischer Titration Kyoto Electronics Manufacturing Co., Ltd. Moisture of paint ·Summary- Checked the possibility of measuring moisture of paint with MKA-520, andgoodrepeatability was obtained. -Measuring instrument- Main unit:MKA-520 Volumetric KF moisture titrator Electrode: M-714 Twin platinum electrode -Reagent- Titrant: Composite 5K (f=4.9034mgH2O/mL) Dehydrating solvent: Dehydrating solvent CE -Measurement method- Preparation: (1) Fill the titration vessel with Dehydrating solvent CE. (2) Pre-titrate for dehydration. (3) Determine the factor of titrant. Measurement: (1) Place 5g sample in the titration vessel with the syringe before measuring the moisture inthe sample. -Equation- Moisture(%): ((DataxF-Driftxt-Blank)/(Wt1-Wt2))x0.1Data :Volume at EP (mL) Blank :Blank value (mg)F: Factor of titrant (mg/mL) Wt1 : Tare including sample weight (g)Drift : Drift before measurement (ug/min) Wt2 : Tare including residual weight (g)t : Measuring time (min) -Standard method- Karl Fischer method -Ambient conditions- Temperature: 24 ℃ R. Humidity: 53% Weather: Fine 京都电子工业株朱会社-可睦电子(上海)商贸有限公司上海市漕溪路222号航天大厦北楼902室电话:021-54488867 电邮: kemu-kem@163. com网址: http://www.kyoto-kem.net.cn -Measurement parameter- -Printout data- Method 1 Titr Mode 1 Titr Buret No. 2 End Time 30 s Final Vol. 0.01 mL Titr Speed Slow Detector Mode 1 t(stir) 60 s t(wait) 10 s t(max) Os Drift Titr : On Start : Manual Max. Volume: 40mL Dose mode:Off Oven : Off [Calculation] Clac.No. 2 Unit :% Weight : \Variable Drift Comp.:Off [Data List Data List Data Samp. Time 30 s: Off Graphic Form Off Method 1 Clac. No. 2 ***Result***Sample No. 01-01 Date 2008/10/0415:48 Wt1 5.6663gWt2 0g Net 5.6663g Blank 0.0 mg Result 0.1389% Bur. No.1 1.605 mL 7.8700 mg Titr. Time 00 : 03:12 ***Result**** Sample No. 01-02 Date 2008/10/0416:10Wt155.5710g Wt2 0g Net 5.5710g Blank 0.0 mg Result 0.1404% Bur. No.1 1.595 mL 7.8209 mg Titr. Time 00:03:26 ***Result*** Sample No. 01-03 Date 2008/10/0416:15 Wt1 5.3530 gWt2 0g Net 5.3530 g Blank 0.0 mg Result 0.1406% Bur. No.1 1.535 mL 7.5267 mg Titr. Time 00:02:44 -Measurement results- Run Sample size(g) Titer (mL) Moisture(%) 123 5.6663 5.5710 5.3530 1.605 1.595 1.535 0.1389 0.1404 0.1406 Statistics MeanSD RSD 0.1400 %0.0009% 0.6638% .Comments- Use the reagent for ketone because the sample is a paint. ( 京都电子工业株式会社-可睦电子(上海)商贸有限公司 电话:0 2 1-54488867 电邮: ke mu-kem@163. com )
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《涂料中水分含量检测方案 》,该方案主要用于涂料中水分含量检测,参考标准《暂无》,《涂料中水分含量检测方案 》用到的仪器有MKH-710M容量法库仑法混合型卡尔费休水分仪、MKV-710B卡尔费休容量法水分测定仪、MKV-710S豪华型容量法卡尔费休水分仪、MKV-710M四通道旗舰型容量法卡尔费休水分仪。
