15th Int Symp on Applications of Laser Techniques to Fluid MechanicsLisbon, Portugal, 05-08 July, 2010Paper Number 1727 Shear Layer Dynamics of a Cylindrical Cavity forDifferent Acoustic Resonance Modes Gareth J. Bennett,Francisco Rodriguez Verdugo, David B. Stephens’ 1: Department of Mechanical and Manufacturing Engineering, Trinity College, Dublin 2, Ireland, gareth.bennett@tcd.ie2: Dipartimento di Ingegneria Meccanica Industriale, Universita degli Studi Roma Tre, Italy, frodrig@tcd.ie3: NASA Glenn Research Centre, USA, David.Stephens@nasa.gov Abstract This paper investigates the interaction between the shear layer over a circular cavity and the flow-excited acoustic response of the volume to shear layer instability modes. Within the fluid-resonant categoryof cavity oscillation, most research has been carried out on rectangular geometries and where cylinders areconsidered, side branch and Helmholtz oscillators are most common. In these studies, focus is generallyrestricted to either longitudinal standing waves or to Helmholtz resonance. In practical situations however,where the cavity is subject to a range of flow speeds, many different resonant mode types may be excited.The current work presents a cylindrical cavity design where Helmholtz oscillation, longitudinal resonanceand also azimuthal acoustic modes may all be excited upon varying the flow speed. Experiments performedshow how lock-on between each of the three fluid-resonances and shear-layer instability modes can beengenerated. A circumferential array of microphones flush mounted with the internal surface of the cavity wallwas used to decompose the acoustic pressure field into acoustic modes and has verified the excitation ofhigher order azimuthal modes by the shear layer. One of these interior pressure signals was also used toprovide a phase signal for averaging flow field measurements of the shear layer acquired using PIV.Observation of the PIV images provides insight into these acoustically coupled oscillations. 1.Introduction Shear layer driven cavity flows can exhibit several types of features generally described asresonance. The review paper of Rockwell and Naudascher (Rockwell and Naudascher 1978)categorized self-sustaining oscillations into three groups: fluid-dynamic; fluid-resonant; and fluid-elastic. Of these, self-sustaining cavity oscillations which are strongly coupled with resonant waveswithin the cavity may be classified as fluid-resonant oscillations. ·Oscillat1ions of this class occur atsufficiently high frequencies such that the corresponding acoustic wavelength is of the same orderof magnitude, or smaller, than the cavity characteristic length-considered here to be the height ofthe cylindrical cavity, H. For ideal organ pipe conditions, these oscillations are predicted to have anacoustic wavelength of a≤2H for a closed cavity end condition. The exact frequency at whichthese longitudinal modes (standing waves along the height of the cavity) occur for shear layerdriven oscillations is complicated by the very presence of the shear layer. Within the fluid-dynamic category, a highly cited work is for high Mach number (M>0.5) flowover a shallow cavity known as a Rossiter cavity. In this system, the feedback mechanism is anupstream-travelling acoustic wave generated by turbulent structures hitting the downstream edge ofthe cavity. These acoustic waves have a wavelength close to the cavity opening dimension, orlength, L. Resonance occurs if this acoustic frequency can excite the shear layer oscillation. Thefluid-elastic category occurs when one or more wall of the cavity undergoes a displacement thatexerts a feedback control on the shear layer perturbation. For cavities with rigid boundaries, the fluid-resonant category may contribute significantly tounwanted noise: from aircraft landing gear for example; or to undesirable pressure pulsations suchas may be experienced in vehicles with open windows. A recent study by Langtry and Spalart(Langtry and Spalart 2008) used computational methods to predict the unsteady pressure inside a landinggear wheelwell or a commercial aircraft geometry. Balasubramaniannfetital(Balasubramanian et al. 2009) have recently considered“sunroof buffeting”on a simplified vehiclegeometry. Tonon et al. (Tonon et al. 2010) have studied a series of side branch resonators as amodel for flow in a corrugated pipe. Height modes were also studied by Yang et al. (Yang et al.2009) who specifically analyzed the effect of the stream wise dimension of the cavity. A coaxialside branch configuration was studied by Oshkai and Yan (Oshkai and Yan 2008). Kook and Mongeau (Kook and Mongeau 2002) and Ma et al. (Ma et al. 2009) have bothrecently studied Helmholtz resonators and accurately predicted the magnitude of the interior cavitypressure, when adequate information about the shear layer is available. Higher order acousticmodes have been explored for an axisymmetric shallow cavity configuration in a work by Awnyand Ziada (Awny and Ziada 2008), and the work of Oshkai et al. (Oshkai et al. 2005) illustrateswell how PIV can be used to gain further insight into the study of shear layer flows. To date, within the fluid-resonant category, almost no consideration has been given to higherorder acoustic modes which might resonate in cavities. In this paper we are particularly interested inexploring the test case where a number of different types of resonant behavior can be exciteddepending on flow speed or orifice geometry. In practical cases, such as for aircraft take-off andlanding where the flow speed varies, it is important to be able to predict these modes so thatmitigation measures can be implemented. 2. Acoustic Pressure Field in a Cylindrical Duct The cavities to be considered as in this experimental work are cylindrical with a small L/H ratio. Asthe longitudinal dimension of the cavity, H, is large, we can consider the cavity to be a closed endedcylindrical duct. The most common situation to be found in the literature is for a plane travellingacoustic wave which reflects from the end to form a standing wave. In cylindrical ducts, planewaves, only, can propagate below a characteristic frequency which is a function of the ductdiameter. In this paper, higher order acoustic modes which are excited above this frequency areconsidered. These modes, once they “cut-on”, have a much more complicated pressure patterncompared to the plane wave mode. When more than one mode has “cut-on”, these modes aresuperimposed upon the plane wave mode and can co-exist with each other. The usual approach inthe analysis of duct acoustics is to solve the defining differential equations by a separation ofvariables technique. This leads to an eigenvalue problem, the solution of which gives the ductpropagation modes. Each mode represents a different way in which sound may travel down theduct. A complete description of the sound field in the duct consists of knowing the complexamplitude of each mode. 2.1 Description of Mode Propagation in Hard Walled Cylindrical Ducts For acoustic propagation in an infinite hard walled cylindrical duct with superimposed constantmean flow velocity U, the pressure p=p(r,,x,t), in cylindrical coordinates, as defined by Fig. 1,is found as a solution of the homogeneous convective wave equation, where the substantive derivative is defined to be Fig.1. Polar coordinate system for a cylindrical duct, (r,0,t) This solution is found as a combination of the characteristic functions of equation (1) each of whichsatisfies specific boundary conditions. Rigorous treatments of the derivation of the separation-of-variables solution can be found in the literature, see Munjal for example (Munjal 1987). For thefollowing assumptions that; · The flow is incompressible and isentropic with negligible temperature gradients 。 The mean flow speed, U=(Ux, 0, 0) is stationary with time · The axial mean flow profile as well as the duct cross-sectional area is invariant in theaxial direction The mean temperature and the density are stationary in space and time the solution to the wave equation for the complex pressure can be given by a linear superposition ofmodal terms: where Amn and Amn are the complex amplitudes of the modes, kx andkx are the axialwave numbers, and m and n are the azimuthal and radial mode indices respectively. The +superscript refers to the direction of flow whereas the - superscript indicates the parameter to bedefined counter to the flow direction. For the case of a closed ended cavity, reflections from the endare accommodated through superposition of the modes in both axial directions which form standingwaves. In the case of hard-walled acoustic boundary conditions, the modes form an orthogonaleigensystem, with a modal shape factor given by for a non-annular cylinder. In equation (3), J is a Bessel function ofthe first kind of order m withassociated hard-walled cylindrical eigenvalue om.n. R is the duct radius and in order to satisfyorthogonality the normalisation factor is calculated to be The normalisation transforms the orthogonal mode eigensystem into an orthonormal modeeigensystem. A mean flow can be accommodated in the formulation, when required, bymodification of the axial wave numbers which are a function of the mode eigenvalue omn and thefree field propagation wave number, k, which are defined as follows 2.2 Modal Decomposition in Hard Walled Circular Ducts Modal decomposition1San advanced experimental technique which can provide detailedinformation of the modal content of sound propagating in ducts. When the wave number, kmn, inequation (4) is real, the mode (m,n) propagates energy along the duct. This occurs when the mode isexcited above a cut-on frequency which depends on the mode eigenvalue and the duct radius.Modes excited below their cut-on frequency are evanescent and decay exponentially with distancealong the duct. The dimensionless number which expresses the cut-on frequency independently ofthe radius is the term kR, or the Helmholtz number (He). Examples of some of these numbers aregiven in Table 1 for a simple duct with no mean flow or shear layer condition. Table 1. Helmholtz numbers for lower order azimuthal and radial modes [kR or He]. No flow. m,n 0 1 0 0 3.83 1 1.84 5.33 2 3.05 6.71 The modal decomposition performed in this paper is based on the approach proposed by Abom(Abom 1989) whose objective is to measure the modal amplitudes of equation (2). This techniquewas implemented by Bennett (Bennett 2006) for experimental data, and the pressure fielddecomposed such that: Incident and reflected modes can be identified. A mean flow can be accommodated. Radial and azimuthal modes can be identified. Duct-wall flush-mounted microphones only are used for the decomposition. The decomposition is performed for all frequencies (within the range of interest). Data is acquired at all locations simultaneously. Abom's method of modal decomposition isis carried out in two steps. Firstly an azimuthaldecomposition is carried out with microphones equi-azimuthally spaced around the duct. Byrepeating this step at different axial locations, these modes can be decomposed into incident andreflected radial modes. A full description of this method may be found in Bennett (Bennett 2006). From the literature, most research within the fluid-resonant category of cavity oscillation isrestricted to longitudinal standing waves. This corresponds to plane waves of mode order (m, n)=(0,0) propagating down the cavity and reflecting off the termination. However, if acoustic wavesabove a frequency corresponding to a Helmholtz number of He=1.84 are excited, then it is possiblethat the modal structure of the sound will be of a higher order. The purpose of performing a modaldecomposition on the pressure field in the cavity is to identify the modal content of the standingwaves modes at higher frequencies. 3. Experimental Rig Design A cavity resonance experiment that incorporates a number of the above feedback mechanisms hasbeen designed and constructed. As the rig was to be built using a small, low speed wind tunnel, preliminary analysis was required in order to optimally design the cavity given the imposedlimitations. In each of the three fluid-resonant oscillations considered in this paper, viz. HelmholtzResonance, Longitudinal Resonance and Azimuthal Resonance, the acoustic excitation is assumedto be due to instability in the shear layer of flow over the cavity opening. The shear layer excitationfrequency can be estimated using the empirical relationship suggested by Rossiter (Rossiter 1964).Given the low Mach number under consideration in the current paper (M <0.15), the upstream-propagating acoustic feedback mechanism usually associated with Rossiter is not expected to occurin the present experiment, because the acoustic wavelength corresponding to the cavity openinglength would be in the order of 8kHz, far higher than any expected shear layer oscillationfrequency. Rossiter's equation for the shear layer excitation frequency,however, has been used bymany authors to accurately model other feedback mechanisms(Ma, Slaboch and Morris 2009,Rodriguez et al. 2009). This equation is given as where a describes the phase delay and K is the convection velocity of the shear layer normalizedby the free stream velocity and n=1, 2, 3, is the order of the shear layer mode. For low subsonicspeeds as presented here, a=0 has been used by Ma et al (Ma, Slaboch and Morris 2009),arguing that there is no need to consider a phase delay when the convection speed is much less thanthe speed of sound. As can be seen in equation (5), decreasing the characteristic length of the cavityopening, L, increases the excitation frequency for a given flow speed. Similarly, from observation of Table 1, as k=-, increasing the cavity diameter will result in lower cut-on frequencies for theC higher order modes. Thus for the low tunnel speeds available, a large diameter and small orifice was required to achieve the test objectives allowing excitationof the three different fluid-resonance categories considered. Aschematic of the rig can be seen in Fig. 2. The experimentconsists of a 125mm square wind-tunnel test section, with anattached cylindrical cavity of 240mm internal diameter and492mm height. The large diameter of the cylinder was selectedin order to accommodate higher-order azimuthal acousticmodes. The first azimuthal mode should cut-on at 837Hz, andthe second at 1387Hz for this diameter. Initially, a 40mmsquare opening with sharp edges connected the cavity to thewind tunnel, however, openings of different lengthandlocation relative to the cavity centerline were also tested. Fig. 2. Schematic of rig illustrating orifice to closed ended cylindrical cavity. 3.1 Numerical Analysis -Wave Expansion Method (WEM). In order to verify the cavity design prior to construction, a series of numerical simulations wereperformed on a meshed domain of equal dimensions. A highly efficient finite difference method,originally introduced by Caruthers (Caruthers et al. 1996), was used for the analysis. The approachuses wave functions which are exact solutions of the governing differential equations to interpolateon the grid. This code has been examined by Bennett et al. (Bennett et al. 2009) for its applicabilityin ducts. In order to simulate an oscillation in the shear layer, a numerical monopole volume source waslocated at the orifice opening mid-point. The complex pressure is solved in the domain as a function of source frequency and the amplitude can be plotted on the mesh to give an indication of thepressure field in the cavity/windtunnel rig set-up. Some examples of the solution are given in Fig. 3. (c) (d) Fig. 3. Numerical acoustic solution to monopole excitation at orifice opening of cavity and windtunnel test section.Four Helmholtz numbers are shown: a) He=0.78; b) He=1.85;c)He=2.0 and d) He=3.91 For each Helmholtz number, an isometric of the cavity/wind tunnel test section, as well aslongitudinal and axial sections are displayed. The orifice or monopole source location is indicatedby a circle which in this case is off-set from the cavity axis. The Helmholtz numbers chosenillustrate: the first plane wave“depth/height”or longitudinal mode (H1) in Fig. 3. (a); just above thecut-on frequency of the first azimuthal mode (ref. Table 1) in Fig. 3 (AZ1), (b); a combinationazimuthal/longitudinal mode in Fig. 3(AZ1H1) (c) and a combination radial/longitudinal mode inFig. 3. (d). An awareness and understanding of these modes is necessary if a comprehensiveunderstanding of the acoustic behavior of cavities is to be reached. Based on the results of this analysis, it was confirmed that this cavity geometry would allow allthree fluid-resonant category configurations to be excited by a cavity orifice of approximately40mm in the flow range of the wind tunnel available for the tests. 3.2 Test-set up A low speed LaVision PIV system was used. The seeding particles of DEHS were generated byLaVision Aerosol Generator which had a typical particle size of 1E-6m.A double pulsed Nd:YAG-laser was used to illuminate the flow field. Images were taken with a digital Flow Master CCDcamera equipped with a 28mm focal length lens and a 1279pxx1023px CCD sensor. These werethen processed using Davis 7.2 software and exported into Matlab for further post processing. Therecording rate of the system was fixed to 4Hz. A draw-down wind tunnel with an elliptical bell-mouth inlet was used with a square test section(125mm x 125mm) 335mm in length. The cavity height is 493mm and 119.25mm in radius. Theorifice spanned the test section with a real depth of 7.75mm and a sharp chamfer at 45 degrees. 4. Results and Discussion Once the rig was built, some preliminary tests were performed to verify the cavity response toexcitation. An initial test was performed with a small loudspeaker radiating broadband noise locatedin the tunnel test section in the proximity of the orifice. A transfer function between the speakerinput signal and a microphone flush mounted with the inside surface of the cavity was calculatedand its magnitude is plotted in Fig. 4 (red). Qualitatively, this compares extremely closely to asimilar analysis performed on the numerical data (black), where the transfer function was calculatedbetween the monopole source and a location equivalent the microphone position. Each of thelongitudinal, azimuthal and combination modes are identified. The exception to this is theHelmholtz resonance in the numerical data which poorly models the compressibility effect. Inaddition there is a small (4Hz) frequency shift between the WEM peaks and those measured withthe speaker experiment. As the numerical solution has been found to be very sensitive to changes inthe duct geometry, it is thought that this may be due to the difference in location of the monopolesource and the equivalent acoustic source due to the loudspeaker. Fig. 4. Acoustic response of the cavity for under simulated and experimental conditions. Similarly, the response from the same microphone located in the cavity is plotted for a tunnelflow velocity of approximately 21m/s (blue). Again there is excellent qualitative agreement with nofrequency difference between these results and those when using the loudspeaker. There ishowever, a significant amount of low frequency noise which is presumed to originate from thecentrifugal blower and ducting of the wind tunnel. Following the initial tests, an automated velocity sweep of the tunnel was performed usingLabView to control the centrifugal blower motor speed controller. These results are presented inFig. 5. with shear layer modes calculated according to equation (5) superimposed onto the plot. Arange of convection speed coefficients are to be found in the literature although often at a value ofapproximately K=0.38: ((Ma, Slaboch and Morri;s 2009, Rodriguez, Guitton, Camussi andGrottadaurea 2009, Rossiter 1964). A value of K=0.42 has been used here as a best fit to themeasured data. Audible tones in the region of the Helmholtz frequency were clearly heard and are seen here tobe excited at low flow speeds by the first shear layer instability mode (approx. 7m/s). Theresonance frequency measured compares extremely well with a theoretical value of 74Hzsuperimposed on Fig. 5. Given the thin wall forming the neck of the resonator, an “equivalent neck”approach is used to calculate the Helmholtz resonance frequency as developed by Ma et al. (Ma,Slaboch and Morris 2009): where S is the plan-view cross sectional opening of the orifice (40mmX40mm), l is the equivalentneck length (40mm), V is the volume of the cavity and c is the speed of sound. dB Velocity (m/s) Fig.5. Acoustic response inside the cavity as a function of tunnel flow-speed. Superimposed on the plot are thetheoretical shear layer modes (equation 5) and also the three sets of fluid-resonant categories investigated. For higher flow speeds, an intense lock-in with the first cavity longitudinal mode (H1) isgenerated, again by the first shear layer instability mode. The amplitude of this tone is so great thata non-linear response is generated which results in the first and second harmonics to be excited and is seen in the plot at higher frequencies. The lock-on subsequentlydrops out at higher velocities as the shear layer mode increases infrequency above the first longitudinal mode frequency. At highervelocities, the second shear layer mode locks on to the thirdlongitudinal mode and switching between the two frequencies wasaudible. A time/frequency domain analysis on this data will beperformed to further examine this process. The second and thirdshear layer modes also cause lock on with the H1 mode andamplification of the azimuthal and azimuthal combination modes(AZ1 and AZ1H1) is clearly evident at high velocities. Also identified in Fig. 5 is the combination longitudinal modeof wind tunnel width and cavity height. As the shear layer isbounded, transverse to the flow direction, by the wind tunnel wallon one side and by the cavity termination on the other, the Fig. 6. Photograph of rig showing the cavity, square test-section, wind-tunnel, microphone array and the PIV system. first shear layer mode excites a standing wave which is formed between these two surfaces and canbe seen to lock on at approximately 27m/s. In order to gain further insight into the modal content of the peaks seen in Fig. 5, a fullazimuthal decomposition was performed in the cavity. An array of microphones was mounted intwo rings of eight such that they were flush mounted with the inside of the cavity. Thisconfiguration allows azimuthal modes of up to order Am=A3 to be resolved in both axial directions.A photograph of the rig is to be seen in Fig. 6. A radial mode analysis was not performed on thisset-up as radial modes cut-on above the frequency range of interest. A modal decomposition of the acoustic field inside the cavity for a flow speed of 21m/s usingall sixteen of these microphones is given in Fig.7. This is a very good result which shows clearlythe modal content of the acoustic field in the cavity as a function of frequency, and agrees with theresults given by the numerical analysis. Modes Am=A2 and Am=A3 have been included in thedecomposition, but as they cut-on at higher frequencies (above He=3) their modal amplitudes arecalculated as being insignificant. As expected, although the Am=A mode cuts-on at aroundHe=1.84, it does not remain dominant for all frequencies, with the plane wave mode Am=Aoconstituting the H3 standing wave resonance. Fig. 7. Modal decomposition of the acoustic field inside the cavity for a flow speed of 21m/s. A modal decomposition was performed at each velocity point in the range of the tunnel and thedominant mode for each frequency bin is plotted in Fig. 8. The objective of this exercise was to seeif there was a dependence of modal content on such parameters as flow speed, shear layer mode andlock-on. For low velocities, no change in modal content as a function of these parameters is to beobserved. At higher velocities, however, this test is inconclusive due to the fact that the electretmicrophones used saturated above 36m/s due to their relatively high sensitivity and the highamplitude of the lock-on tone at high velocities. This means of presenting the data, via a waterfallplot, is seen to be most informative however, showing more detail than the standard colour plot ofFig.5. PIV measurements of the orifice region allow greater insight into the fluid dynamics of the shearlayer to be gained. For specific frequencies such as those at lock on, coherent structures can beidentified by phase averaging the images using a pressure signal in the cavity. Where the oscillationto be examined is dominant, this can be straightforward. In Fig. 9(a), the pressure signal is seen tobe dominated by resonance in the cavity of the first longitudinal mode excited by the first shearlayer instability mode. This reference signal is used to phase average the PIV images. A period ofimages corresponding to this test point is given in Fig. 10 (a). For this case, the phase averaging clearly shows a single vortex, corresponding to the first instability mode, convecting in the shear Frequency (kR) Fig. 8. Modal decomposition of the acoustic field inside the cavity for the complete range of flow speeds. The dominantmode at each frequency bin only is plotted. (a) (b) Fig. 9. Illustration of frequency domain filtering of the reference pressure signal used to phase average the PIV images.Three velocities are shown: (a) 43m/s; (b) 7m/s and (c) 21m/s. layer. Fig. 9 (b) shows the pressure signal for a different test point corresponding to the first shearlayer mode exciting the Helmholtz resonance frequency. Again, the phase averaging of the PIVimages, to be seen in Fig. 10 (b), produces clear vorticity plots for a single period. For test pointswhere the resonance under examination no longer dominates the pressure field, the results from thephase averaging can be less clear. Band pass filtering the signal, Fig.9 (C), can improve the PIVanalysis, results of which can be seen in Fig. 10 (c). Although the coherent structures are lessdefined in comparison with the test points shown in Figs 10 (a) and (b), two distinct regions of vorticity can be identified. These correspond to the two vortices which convect at twice the speed ofthe single vortex to be found in the first shear layer mode. 4 Fig. 10. PIV results at cavity orifice for excitation of different fluid-resonant oscillations. Fig. 10. (a): Excitation of thefirst longitudinal mode, H1, by the first shear layer mode; Fig. 10. (b):Excitation of the first longitudinal mode, H1, bythe second shear layer mode; Fig. 10. (C): Excitation of the Helmholtz Resonance,HR, by the first shear layer mode.Each sequence of eight images corresponds to one complete phase averaged period for the frequency underexamination. The PIV analysis provides important insight, where the behaviour of the shear layer is seen todiffer dramatically from one mode to the next. For the first shear layer lock on mode, Fig. 10 (a), aclear roll-up begins at the leading edge with the distinct single vortex convecting downstream andimpinging on the trailing edge. For the Helmholtz Resonance, the roll-up begins much closer to thetrailing edge and “flapping”of the shear layer is evident. This is caused by the acoustic particlevelocity oscillating at the neck, transverse to the flow. The velocity vectors on either side of theshear layer for the test point corresponding to Fig. 10 (c), although not shown here, have beenexamined. Unlike the other two test cases, where the velocity vectors rotate clockwise inaccordance with the phase point, facilitating roll-up, the vectors for the second shear layer moderemain parallel: in the direction of the flow above the shear layer and parallel but counter flow direction below the shear layer. This adverse shear layer behaviour explains the less distinctcoherent structures, where the turbulent length scales decrease and are dissipated as the vortexconvects downstream towards the trailing edge. In addition, examination of individual frames forthis test point occasionally show only single vortices. This manifests as a peak in Fig. 5 at half thefrequency, particularly clear at approximately 18m/s. There appears to be switching between thetwo shear layer modes for this velocity. The presence of the single vortex in some frames, whilst ofgreat interest physically, tends to reduce the clarity of the phase averaged results. 5.Conclusions A cylindrical cavity experiment which allows different modes of resonant behaviour to be exciteddepending on flow speed and orifice geometry has been design and constructed. Specifically,modes falling into the fluid-resonant category, viz., Helmholtz resonance, Longitudinal resonanceand Azimuthal resonance, have all been excited by different shear layer oscillation modes. Lock onbetween these different resonant modes and shear layer excitation has been clearly measured andobserved to occur upon adjusting only the flow speed. An azimuthal acoustic modal decompositionwas performed and verified the modal composition of the resonances. Phase averaged PIV allowedthe coherent structures present in the shear layer to be examined and the interaction between thecavity resonance and the shear layer oscillation to be observed. Acknowledgements Dr. Stephens was supported as a visiting scholar at Trinity College by the Erasmus Mundus Masterof Mechanical Engineering programme. References Abom M (1989) Modal Decomposition in Ducts Based On Transfer Function Measurements Between Microphone Pairs. Journal of Sound andVibration 135:95-114 Awny K, Ziada S (2008) Effect of Cavity Depth on Diametral Mode Excitation 9th International Conference on Flow-Induced Vibrations (FIV2008).Prague, Czech Republic, Balasubramanian G, Crouse B, Freed D (2009) Numerical Simulation of Leakage Effects on Sunroof Buffeting of an Idealized Generic Vehicle 15thAIAA/CEAS Aeroacoustics Conference.Miama, Florida, Bennett G (2006) Noise Source Identification For Ducted Fans Mechanical and Manufacturing Engineering. University of Dublin, Trinity CollegeDublin. Bennett GJ, O'Reilly C, Tapken U, Liu H (2009)Modelling multi-modal sound transmission from point sources in ducts with flow using a wave-based method 16th International Congress on Sound and Vibration (ICSV16). Krakow, Poland, Caruthers JE, Engels RC, Ravinprakash GK (1996) A wave expansion computational method for discrete frequency acoustics within inhomogeneousflows 2nd AIAA/CEAS Aeroacoustics Conference. State College, Pennsylvania, Kook H, Mongeau L (2002) Analysis of the periodic pressure fluctuations induced by flow over a cavity. Journal of Sound and Vibration 251:823-846 Langtry RB, Spalart PR (2008) DES Investigation of a Baffle Device for Reducing Landing-Gear Cavity Noise 46th AIAA Aerospace SciencesMeeting and Exhibit. Reno, Nevada, ( M a R, Slaboch PE, Morris SC (2 0 09) Flui d mechanics of t he flow-excited Helmholtz resonator. Journal of Fluid Mechanics 623:1-26 M unjal ML (19 8 7) Acoustics of Ducts and Mufflers. Wiley, ) Oshkai P, Geveci M, Rockwell D, Pollack M (2005) Imaging ofacoustically coupled oscillations due to flowpast a shallow cavity: effect of cavitylength scale. Journal of Fluids and Structures 20:277-308 Oshkai P, Yan T (2008)Experimental investigation of coaxial side branch resonators. Journal of Fluids and Structures 24:589-603 Rockwell D,Naudascher E (1978) Review -Self-Sustaining Oscillations of Flow Past Cavities. J Fluid Eng-T Asme 100:152-165 Rodriguez F, Guitton A, Camussi R, Grottadaurea M (2009) Experimental Investigation of a Cylindrical Cavity 15th AIAA/CEAS AeroacousticsConference. Miami, Florida, Rossiter JE (1964) Wind Tunnel Experiments on the flow over rectangular cavities at subsonic and transonic speeds. Technical Report 64037 RAETonon D, Landry BJT, Belfroid SPC, Willems JFH, Hofmans GCJ, Hirschberg A (2010) Whistling ofa pipe system with multiple side branches:Comparison with corrugated pipes.Journal of Sound and Vibration 329:1007-1024 DOI DOI 10.1016/j.jsv.2009.10.020 Yang Y,Rockwell D, Cody KL-F, Pollack M (2009) Generation of tones due to flow past a deep cavity: effect of streamwise length. Journal of Fluids - - --
关闭还剩11页未读,是否继续阅读?
北京欧兰科技发展有限公司为您提供《流体中速度场,边界层,剪切层检测方案(粒子图像测速)》,该方案主要用于其他中速度场,边界层,剪切层检测,参考标准《暂无》,《流体中速度场,边界层,剪切层检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
