缝槽气膜中冷却流动特性的最小介入扰动诊断的实验研究检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共3种
The performance of a propulsion system is directly proportional to its operating
temperature; therefore, an optimum operation regime will undoubtedly generate
intense thermal loads on system components. If the system is designed for reusability
and/or long range missions, it may be necessary to perform active cooling of critical
components to prevent premature failure of the system. One such method is film
cooling, in which a layer of relatively cool gas is injected near the surface to be
protected. This work describes the use of minimally intrusive diagnostics to
characterize the kinematics, thermal dynamics and heat transfer of slot film cooling
flows over a wide range of blowing ratios, generating a comprehensive database for
detailed analysis, as well as for further use by model developers.
北京欧兰科技发展有限公司为您提供《缝槽气膜中冷却流动特性的最小介入扰动诊断的实验研究检测方案(粒子图像测速)》,该方案主要用于其他中冷却流动特性的最小介入扰动诊断的实验研究检测,参考标准《暂无》,《缝槽气膜中冷却流动特性的最小介入扰动诊断的实验研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机、PLIF平面激光诱导荧光火焰燃烧检测系统。
我要纠错
