湍动,稳定环形分层火焰中速度场,自由基,羟基,浓度场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场,自由基,羟基,浓度场
关联设备
共3种
A burner for investigating lean stratified premixed flames propagating in intense
isotropic turbulence has been developed. Lean pre-mixtures of methane at different
equivalence ratios are divided between two concentric co-flows to obtain annular
stratification. Turbulence generators are used to control the level of turbulence intensity
in the oncoming flow. A third annular weakly swirling air flow provides the flame
stabilization mechanism. A fundamental characteristic is that flame stabilization does
not rely on flow recirculation. The flames are maintained at a position where the local
mass flux balances the burning rate, the result is a freely propagating turbulent flame
front. The absence of physical surfaces in the vicinity of the flame provides free access
for laser diagnostics.
Stereoscopic Planar Image Velocimetry (SPIV) has been applied to obtain the three
components of the instantaneous velocity vectors on a vertical plane above the burner
outlet where the flames propagate. The instantaneous temperature fields have been
determined through Laser Induced Rayleigh (LIRay) scattering. Planar Laser Induced
Fluorescence (PLIF) on acetone has been used to calculate the average equivalence ratio
distributions. Instantaneous turbulent burning velocities have been extracted from SPIV
results, while flame curvature and flame thermal thickness values have been calculated
using the instantaneous temperature fields. The probability distributions of these
quantities have been compared considering the separate influence of equivalence ratio
stratification and turbulence.
北京欧兰科技发展有限公司为您提供《湍动,稳定环形分层火焰中速度场,自由基,羟基,浓度场检测方案(粒子图像测速)》,该方案主要用于其他中速度场,自由基,羟基,浓度场检测,参考标准《暂无》,《湍动,稳定环形分层火焰中速度场,自由基,羟基,浓度场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、PLIF平面激光诱导荧光火焰燃烧检测系统、时间分辨平面激光诱导荧光测量系统。
我要纠错
