Kyoto Electronics Manufacturing Co., Ltd.Data No.LA47-07251 No.EKCR-07273 KEM Application Note No.EKCR-07273 Coulometric Karl-Fischer Titration Moisture of N-66 polymer Summary- Checked the possibility of measuring moisture of N-66 polymer in combination of MKC-520with ADP-511S, and good repeatability was obtained. -Measuring instrument- Main unit:MKC-520 Coulometric KF moisture titrator Option: ADP-511SEvaporator Electrode:M-713 Twin platinum electrode #433-0006Inner burette -Reagent- Anolyte: Coulomat AG Catholyte:(Coulomat CG Carriergas: Nitrogen -Measurement method- Preparation: (1) Fill the titration cell with the anolyte and inner burette with the catholyte. (2) Pretitrate for dehydration. (3) Connect MKC-520 with ADP-511S and set the nitrogen flow at 200mL/min and theevaporation temperature at 200°℃. Measurement: (1) Place 1g sample in the sample boat and measure for its moisture. -Equation- Moisture (ppm): ((Data-Driftxt-Blank)/(Wt1-Wt2))xF Data : Measured water content (ug) Drift : Drift before measurement (ug/s)t : Measuring time(s) Blank : Blank value(ug) Wt1 : Tare including sample weight (g) Wt2 : Tare including residual weight (g) F : Factor (1.00) Standard method- Karl Fischer method -Ambient conditions- Temperature:25 ℃ R. Humidity: 61% Weather: Rain Http://www. shxf17.com -Measurement parameter- -Printout data- 「Titration] Method 4 Titr. Cell No. 1 t(stir) 300 s t(wait) 15 s t(max) 1800 s Drift Stop : Rel 0.01 ug/s Cont. Gain 5.0 Stable 0.1 ug/min Start :Manual Oven : ADP- Oven Temp200°℃ Pre Treat 2 Back Purge180 s Cell Purge 120 s [Calculation1 Clac. No. 2 Unit :ppm Weight :Variable Drift Comp. : Auto 「Data Listl Samp.Interval 60 s Display : Form2 Print Meas. Data : On Print Graphic : Form2 0 ug 3000 二 00:30:00 ***Res u lt* ** Sample No. 03-01 Date 07/08/31 10:38 Titr. Cell No. 1Wt1 1.0105g Net Wt2 0(g1.0105Drift 0.11ug/sResult 2925.0 yg2894.6 ppm Titr. Time : 00:30: 15 -Measurement results- Run Sample size(g) Moisture(ug) Concentration(ppm) Statistics 123 1.0105 1.0123 0.9847 2925.02912.8 2790.2 2894.6 2878.0 2833.6 MeanSD RSD 2868.7 ppm31.538 ppm1.0994% -Comments- Compared with Karl Fisher Coulometry without a diaphragm. See the No. KCR-07272. Http://www. shxf17. com 上海旭风科学仪器有限公司 上海市闸北区荣路 el: Fax: 周峰 zhou-fengcom
关闭产品配置单
上海旭风科学仪器有限公司为您提供《尼龙66中水分含量检测方案 》,该方案主要用于合成纤维中水分含量检测,参考标准《暂无》,《尼龙66中水分含量检测方案 》用到的仪器有null。
