Kyoto Electronics Manufacturing Co., Ltd.Data No.LN47-10348 No.EKCA-10379网址: http://www.kem-china.com KEM Application Note No.EKCA-10379 Coulometric Karl-Fischer Titration Moisture of Crude oil -Summary- Checked the possibility of measuring moisture of Crude oil with MKC-520, and goodrepeatability was obtained. -Measuring instrument- Main unit:MKC-520 Coulometric KF moisture titrator Electrode: M-713 Twin platinum electrode #433-0006 Inner burette -Reagent- Anolyte: Coulomat AG(60mL)+Xylene(40mL) Catholyte:Coulomat CG -Measurement method- Preparation: (1) Fill the titration cell with the anolyte and the inner burette with the catholyte. (2) Pretitrate for dehydration. Measurement: (1) Place sample in the titration cell and start the measurement. -Equation- Moisture (ppm): ((Data-Driftxt-Blank)/(Wt1-Wt2))xF Data : Measured water content (ug) Drift : Drift before measurement (ug/s) t : Measuring time(s) Blank : Blank value (ug)Wt1: Tare including sample weight (g) Wt2 : Tare including residual weight (g)F:Factor (1.00) -Standard method- Karl Fischer method -Ambient conditions- Temperature: 23℃ R. Humidity: 67% Weather: Rain Titration] Method 1 t(stir) 0s t(wait) 15 s t(max) 0s Drift Stop :Rel 0.1ug/s Cont. Gain 5.0 Stable 0.1 ug/min Start Manual Oven : Off [Calculation Clac. No. 2 Unit :% Weight :\Variable Drift Comp.: Auto [DataList] Samp. Interval 30 sDisplay :Off Print Meas. Data : Off Print Graphic : Off No. i-1 Size t .3727 绣t2 3.81289 tiet 8.35399 Res315 589.9 8.1610 E,5、 .1714/5一- 35.Tie 30:01:47 Size ti 4,486 t2 3.5281 riet 8.4285 654.7 8.1535 B、5. .17 4:=as.Tine 姿1:43 o.1-33 5ize 绣t直 4.0099 t2 3.53189 fiet 8.3781 RS31 614.5 .1625 8.5、 .16 35.Tie 50:01137 Run Sample size (g) Moisture(ug) Concentration(%) 123 0.3539 0.4265 0.3781 569.9 654.7 614.5 0.16100.1535 0.1625 Statistics MeanSD RSD 0.1590%0.0048% 3.0326% ( 京都电子工业株式会社-可睦电子 ( 上 海) 商贸有限公司 电话:0 21-54488867 电邮: kemu-kem@163.com ) 上海市徐汇区中山西路2366弄1号203室
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《原油中水含量检测方案 》,该方案主要用于原油中水含量检测,参考标准《暂无》,《原油中水含量检测方案 》用到的仪器有MKH-710M容量法库仑法混合型卡尔费休水分仪、MKC-710B卡尔费休库仑法微量水分测定仪、MKC-710S豪华型库仑法卡尔费休水分仪、MKC-710M四通道旗舰型库仑法卡尔费休水分仪。
