戴安公司技术注解 AN342 AN342 用加速溶剂萃取(ASE)技术对大体积的鱼肉样品进行PCBs 的测定 PCBs: 多氯联苯 POPs: Priority Organic Pollutants 样品基体:鱼肉组织 仪器: Dionex ASE300 (带有100mL萃取池) Dionex 萃取采集瓶(250mL) HP6890 GC-ECD 试剂: 二氯甲烷(优级纯) Hydromatrix 硅藻土 氧化铝(除去萃取液中共萃取的油脂物质) 萃取条件: 系统压力: 10Mpa (1500psi) 温度: 125℃ 加热时间: 5min 静态时间: 3min 溶剂: 二氯甲烷 冲洗体积: 60% 吹扫时间: 120 秒 静态循环次数:3次 总萃取时间:每个样品18min 溶剂总量: 每个样品120-140mL 样品制备: 称取30g鱼组织,标准加入50uL PCB同类标准溶液(正己烷中),分别含有50~250ug/mL PCB同类物质。最终样品浓度为 80~400ng/g。样品与 20g Hydromatrix硅藻土混合并研磨,然后装入已装有10g氧化铝的 100mL 萃取池中。 分析结果: Table 1 Recovery of Spiked PCB Congeners from 30-g Fish Tissue Samples Using Selective ASE Extraction Conditions Congener BZ# Spike(ig) %Recovery %RSD 2-Chlorobiphenyl2,3-Dichlarobiphenyl 2,4,5-Trichlorobiphenyl2,2,4.6-Tetrachlorobiphenyl2,2,3,4,5'-Pentachlorobiphenyl2,2,4A',5,6-Hexachlorobiphenyl2.2,3A'5,6,6'-Heptachlorobipheryl2,2,3,3'4,5',6.6-Octachlorobipheny Decachlorobipherrd 15295087154186200209 252525555757512.5 99.8103.8107.198492.389.091.196.094.2 3.0883.124395.98.5658.7 Figare I.GC/ECD mmalysis ofA) ICR corgeer shandurrds, B)ASE fasktissue catract, amd C) ASE fisk nissae ertract prodaced noeselectively. ( 参考文献 ) ( 1. Dionex Application N o te 327:"Selective Extraction of PCBs f r om Fish T i ssue”. Dionex C o rporation, 1996. ) 2. Schantz, M.J Nichols, J.J and Wise, s.“Evaluation of Pressurized Matrix Reference Materials”. Anal.Chem.1997,69.4210-4219 3. Ezzell, J.J Richter B.; and Francis, E.“Selective Extraction of PCBs from Fish Tissue UsingAccelerated Solvent Extraction”. Amer. Environ. Lab. December 1996, 12-13. ( 4. “Test Methods for Evaluating Solid Waste , Method 3545”. U.S. EPA sw-846, Update Ⅲ . Fed. Regist.Vol. 62, 114:32451. U.S. GPO:Washington, DC , June 13, 19 9 7 )
关闭产品配置单
赛默飞色谱与质谱为您提供《鱼肉中多氯联苯检测方案 》,该方案主要用于水产品中环境污染物检测,参考标准《暂无》,《鱼肉中多氯联苯检测方案 》用到的仪器有赛默飞Dionex ASE 150快速溶剂萃取仪。
