鸟禽中胚胎心脏血浆的流动状态检测方案(粒子图像测速)
检测样品
家禽
检测项目
动物营养与健康
关联设备
共3种
The measurement of blood-plasma velocity distributions with spatial and temporal resolution in vivo is inevitable for the
determination of shear stress distributions in complex geometries at unsteady flow conditions like in the beating heart. A nonintrusive,
whole-field velocity measurement technique is required that is capable of measuring instantaneous flow fields at submillimeter
scales in highly unsteady flows. Micro particle image velocimetry ðmPIVÞ meets these demands, but requires special
consideration and methodologies in order to be utilized for in vivo studies in medical and biological research.
We adapt mPIV to measure the blood-plasma velocity in the beating heart of a chicken embryo. In the current work, bio-inert,
fluorescent liposomes with a nominal diameter of 400nm are added to the flow as a tracer. Because of their small dimension and
neutral buoyancy the liposomes closely follow the movement of the blood-plasma and allow the determination of the velocity
gradient close to the wall. The measurements quantitatively resolve the velocity distribution in the developing ventricle and atrium
of the embryo at nine different stages within the cardiac cycle. Up to 400 velocity vectors per measurement give detailed insight into
the fluid dynamics of the primitive beating heart. A rapid peristaltic contraction accelerates the flow to peak velocities of 26 mm/s,
with the velocity distribution showing a distinct asymmetrical profile in the highly curved section of the outflow tract.
In relation to earlier published gene-expression experiments, the results underline the significance of fluid forces for embryonic
cardiogenesis. In general, the measurements demonstrate that mPIV has the potential to develop into a general tool for instationary
flow conditions in complex flow geometries encountered in cardiovascular research.
北京欧兰科技发展有限公司为您提供《鸟禽中胚胎心脏血浆的流动状态检测方案(粒子图像测速)》,该方案主要用于家禽中动物营养与健康检测,参考标准《暂无》,《鸟禽中胚胎心脏血浆的流动状态检测方案(粒子图像测速)》用到的仪器有电动层析显微粒子成像测速PIV-Mitas、Imager sCMOS PIV相机、PLIF平面激光诱导荧光火焰燃烧检测系统。
我要纠错
