油漆,液滴中粒径,速度,荷质比分布,静电旋转钟喷雾模拟检测方案(激光粒度仪)
检测样品
其他
检测项目
关联设备
共3种
下载方案
High-speed electrostatic rotary bells are widely used in the
automotive industry as they provide high quality paint films
with better transfer efficiency compared to air-atomizing guns.
However, due to its highly turbulent spray pattern, transfer
efficiency is still not ideal, i.e. some portion of paint will not
reach intended target surfaces and becomes overspray.
Numerical simulation of the electrostatic spraying process
provides a tool to model this process as well as a way to
optimize transfer efficiency.
Currently, the state-of-the-art simulation model can
simulate the flying trajectories of paint droplets from the edge
of the rotating bell cup to the target surfaces. It requires some
input information to start the simulation. The input information
includes paint droplet size, velocity, and charge-to-mass ratio.
Due to its large number of droplets, distributions based on
droplet diameters are used to represent the entire droplet
population.
This paper describes experimental and mathematical
methods to measure and calculate paint droplet size, velocity,
and charge-to-mass ratio distributions. The resulting
information can then be organized and used as the input data
files for Electrostatic spray painting simulation.
北京欧兰科技发展有限公司为您提供《油漆,液滴中粒径,速度,荷质比分布,静电旋转钟喷雾模拟检测方案(激光粒度仪)》,该方案主要用于其他中粒径,速度,荷质比分布,静电旋转钟喷雾模拟检测,参考标准《暂无》,《油漆,液滴中粒径,速度,荷质比分布,静电旋转钟喷雾模拟检测方案(激光粒度仪)》用到的仪器有LaVision ParticleMaster-Shadow 粒径测量系统、德国LaVision PIV/PLIF粒子成像测速场仪、三维立体PIV。
我要纠错
