当前位置: 其他 > 方案详情
发动机中缸内傅里叶变换红外光谱学检测方案(尾气检测)
检测样品 其他
检测项目 缸内傅里叶变换红外光谱学
关联设备 共3种 下载方案
方案详情
We have adapted a standard Fourier-transform infrared (FTIR) spectrometer (Thermo-Scientific Nexus 670) for in-cylinder measurements of gas spectra. During engine operation, the engine shaft encoder signal is logged continuously along with the FTIR’s He–Ne laser signal and infrared interferogram signal. The engine piston and FTIR mirror move in an uncorrelated fashion, so that after many minutes of engine operation, a complete interferogram is populated at each piston position. Afterward, the data are compiled into a series of spectra versus crank-angle degree. Here, we present a near-infrared H2O thermal emission spectrum measured through a fiber-optic spark plug connected to an engine
关闭
产品配置单
北京欧兰科技发展有限公司为您提供《发动机中缸内傅里叶变换红外光谱学检测方案(尾气检测)》,该方案主要用于其他中缸内傅里叶变换红外光谱学检测,参考标准《暂无》,《发动机中缸内傅里叶变换红外光谱学检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统、德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
我要纠错
推荐专场
相关方案
