当前位置: 其他 > 方案详情
内燃机缸内的滚流中滚流粒子成像检测方案(粒子图像测速)
检测样品 其他
检测项目 滚流粒子成像
关联设备 共2种 下载方案
方案详情
Now-a-days, the stratified and direct injection spark ignition engines are becoming very popular because of their low fuel consumption and exhaust emissions. But, the challenges to them are the formation and control of the charge which is mainly dependent on the in-cylinder fluid flows. Today, an optical tool like particle image velocimetry (PIV) is extensively used for the in-cylinder fluid flow measurements. This paper deals with the experimental investigations of the in-cylinder fluid tumble flows in a motored internal combustion engine with a flat piston at different engine speeds during intake and compression strokes using PIV. The two-dimensional in-cylinder flow measurements and analysis of tumble flows have been carried out in the combustion space on a vertical plane at the cylinder axis. To analyze the fluid flows, ensemble average velocity vectors have been used. To characterize the tumble flow, tumble ratio has been estimated. From the results, it is found that the tumble ratio mainly varies with crank angle positions. At the end of compression stroke, maximum turbulent kinetic energy is more at higher engine speeds. Present study will be very useful in understanding the effect of engine speeds on the in-cylinder fluid tumble flows under real engine conditions.
关闭
产品配置单
北京欧兰科技发展有限公司为您提供《内燃机缸内的滚流中滚流粒子成像检测方案(粒子图像测速)》,该方案主要用于其他中滚流粒子成像检测,参考标准《暂无》,《内燃机缸内的滚流中滚流粒子成像检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、汽车发动机多参量测试系统。
我要纠错
推荐专场
相关方案
