燃料,喷雾,液滴中粒径,速度,形状检测方案(激光粒度仪)
检测样品
其他
检测项目
粒径,速度,形状
关联设备
共3种
下载方案
In the present work the process of a transient fuel injection in a constant high-pressure atmosphere is investigated experimentally. As fuel, dimethyl ether (DME) is used. The goal is to receive new information about the charac-teristics referring to the droplet size, the droplet velocity and the droplet shape in the jet. The high-pressure chamber has a constant pressure of 2 MPa and the fuel spray is injected with a pressure of 6 MPa, 7 MPa and 8 MPa. The spray is analysed by a Shadow-Sizing-technique and digital image analysis with temporal and spatial resolution, which even allows investigating non-spherical droplets. The correlations of d
velocity and droplet shape are presented as Joint Probability Density Functions (JPDF). The conclusion of the investigation shows that little increase of the injection pressure has a remarkable effect on the droplet size. Furthermore, the centricity is widely influenced by the injection pressure. With lower injection pressure the droplet velocity decreases. Moreover, the droplets mean diameter shows a significant decrease with increasing time after the injection
北京欧兰科技发展有限公司为您提供《燃料,喷雾,液滴中粒径,速度,形状检测方案(激光粒度仪)》,该方案主要用于其他中粒径,速度,形状检测,参考标准《暂无》,《燃料,喷雾,液滴中粒径,速度,形状检测方案(激光粒度仪)》用到的仪器有LaVision ParticleMaster-Shadow 粒径测量系统、德国LaVision PIV/PLIF粒子成像测速场仪、Imager LX PIV相机。
我要纠错
