激波中湍动边界层相互作用失稳特性的双平面PIV研究检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共2种
The unsteady organization and temporal dynamics of the interaction between a planar
shock wave impinging on a turbulent boundary layer at a free stream Mach number of
M∞=1.69 is investigated experimentally by means of dual-plane Particle Image Velocimetry
(dual-PIV). Two independent PIV systems were combined in two component mode to obtain
instantaneous velocity fields separated by a prescribed small time delay. This enables to
obtain, in addition to mean and statistical flow properties, also instantaneously time resolved
data to characterize the temporal dynamics of the flow phenomenon in terms of time scales,
temporal correlations and convective velocities. The characteristic time scales for the
incoming boundary layer, the separation region and the reflected shock are evaluated by
means of measuring the temporal auto-correlation coefficient in the complete flow field for a
range of time delays from 5 ms to 2000 ms. These auto-correlation fields are used to quantify
the time scales in selected regions of the flow. This permits resolving the dominant time
scales within the boundary layer and the interaction region.
I. Introduction
北京欧兰科技发展有限公司为您提供《激波中湍动边界层相互作用失稳特性的双平面PIV研究检测方案(粒子图像测速)》,该方案主要用于其他中湍动边界层相互作用失稳特性的双平面PIV研究检测,参考标准《暂无》,《激波中湍动边界层相互作用失稳特性的双平面PIV研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、双平面立体PIV。
我要纠错
