Acceleration is of primal relevance in fluid mechanics, as it shows the effect of the combination of all the forces acting on a fluid flow; the Navier-Stokes equations highlight this fact and the importance of its knowledge in the description of a fluid motion:
Moreover, only in few particular cases (as for example, in parallel fluxes such as Couette one) it is possible to analytically solve them: for the other cases it would be important to measure their single components. Unfortunately, despite the acceleration is at
the very base of fluid motion (see, for instance, Tsinober 2001), only few measurement of the acceleration in the Lagrangian frame can be found in literature. Even if, on one hand, a certain number of authors have studied acceleration properties via numerical simulations, for instance Vedula and Yeung (1999), Tsinober et al. (2001), Biferale et al. (2004), Goto et al. (2005), Osborne et al. (2005), Chen et al. (2006), on the other very few examples of its experimental measure are available up to now. Moreover,among them not all the measurements are taken in the Lagrangian frame: among the
Eulerian measurements, Christensen and Adrian (2002), Dong et al. (2001) and Lowe and Simpson (2005) can be pointed out, among the Lagrangian ones, Virant and Dracos (1997), Ott and Mann (2000), La Porta et al. (2001), Voth et al. (2002) and Luthi et al.(2005) can be found.
北京欧兰科技发展有限公司为您提供《水流中湍流中进行拉格朗日加速度测量检测方案(粒子图像测速)》,该方案主要用于其他中湍流中进行拉格朗日加速度测量检测,参考标准《暂无》,《水流中湍流中进行拉格朗日加速度测量检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
