水流中实验流体力学和计算流体力学的研究检测方案(粒子图像测速)
检测样品
其他
检测项目
实验流体力学和计算流体力学的研究
关联设备
共1种
A complementary experimental and computational study of plunging breaking waves is presented that are generated in
a two dimensional open channel flume using a bottom bump and impulsive accelerated flow. The time evolution of the transient
wave and its flow properties are measured using experimental fluid dynamics (EFD): upstream and downstream velocity
and flow rates using pitot probes; air-water interface elevation measurements and two dimensional particle image velocimetry
in the wave breaking region. The computational fluid dynamics (CFD) methods are: Cartesian grid; embedded-
boundary; hybrid HSM/GF/particle level set and VOF methods, and LES. CFD wave profiles at various time steps
identifies the overall wave breaking process and major events: max wave height, first plunge, oblique splash-up, vertical jet,
air entrainment, two repeats of these processes, dissipation and wave swept downstream which is qualitatively validated by
EFD results. Both EFD and CFD results showed two subsequent plunging and splash-up events after the first plunge. After
the wave breaks, the flow trends in mean velocity and vorticity observed in EFD are very similar to CFD which has more
detailed resolutions of plunging, splashing, vertical jet and bubble entrainment. Current studies also revealed the occurrence
of chaotic multiple splash-up events after the third plunging that produce span-wise vorticity and turbulence. Generation of
a clockwise rotating bump vortex and an anticlockwise rotating span-wise wave breaking vortex that is created from the
entrapped air after the breaking which transports turbulence from the trough towards the bulk fluid, were identified as the
two important events. Mean values of turbulent kinetic energy (TKE) below the broken wave showed that the TKE levels
increase by almost 90% after the first plunge and another 40% after the second plunge, after which as the wave is swept
downstream by the accelerating mean flow the TKE dissipates.
北京欧兰科技发展有限公司为您提供《水流中实验流体力学和计算流体力学的研究检测方案(粒子图像测速)》,该方案主要用于其他中实验流体力学和计算流体力学的研究检测,参考标准《暂无》,《水流中实验流体力学和计算流体力学的研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
