流体中速度矢量场,速度场,体视速度场,3D3C速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共3种
下载方案
Particle Image Velocimetry (PIV) denotes a prevailing technique for
imaging turbulent fluids with high-speed cameras. Corresponding image
sequences provide the basis for estimating such flows and related flow
patterns through image processing. While so far this technique has been
applied in two dimensions (2D) in terms of an illuminated plane intersecting
the volume, recent research focuses on imaging fluids directly in
3D. This paper provides a synopsis of the state-of-the-art and its connections
to previous research work on image restoration. We address
the basic problems involved and point out promising research directions
for reconstructing scalar-valued particle functions from few tomographical
measurements. Solutions to these problems will provide an essential
processing step prior to the estimation of 3D flows from reconstructed
volume functions.
北京欧兰科技发展有限公司为您提供《流体中速度矢量场,速度场,体视速度场,3D3C速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中速度矢量场,速度场,体视速度场,3D3C速度矢量场检测,参考标准《暂无》,《流体中速度矢量场,速度场,体视速度场,3D3C速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、体视层析粒子成像测速系统(Tomo-PIV)、Imager sCMOS PIV相机。
我要纠错
