燃烧,火焰,分层火焰,涡流中速度场,流场,速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场,流场,速度矢量场
关联设备
共3种
下载方案
Stereoscopic Planar Image Velocimetry (SPIV) has been applied to obtain the three
components of the instantaneous velocity vectors on a vertical plane above the burner
outlet where the flames propagate. The instantaneous temperature fields have been
determined through Laser Induced Rayleigh (LIRay) scattering. Planar Laser Induced
Fluorescence (PLIF) on acetone has been used to calculate the average equivalence ratio
distributions. Instantaneous turbulent burning velocities have been extracted from SPIV
results, while flame curvature and flame thermal thickness values have been calculated
using the instantaneous temperature fields. The probability distributions of these
quantities have been compared considering the separate influence of equivalence ratio
stratification and turbulence. It has been observed that increased levels of turbulence
determine higher turbulent burning velocities and flame front wrinkling. Flames
characterized by stronger fuel stratification showed higher values in turbulent burning
velocities. From the curvature analysis emerged that increased fuel concentration
gradients favour flame wrinkling, especially when associated with positive small radius
of curvature. This determines an increased surface area available for reaction that
promotes a faster propagation of the flame front in the oncoming combustible mixtures.
北京欧兰科技发展有限公司为您提供《燃烧,火焰,分层火焰,涡流中速度场,流场,速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中速度场,流场,速度矢量场检测,参考标准《暂无》,《燃烧,火焰,分层火焰,涡流中速度场,流场,速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、PLIF平面激光诱导荧光火焰燃烧检测系统、三维立体PIV。
我要纠错
