喷嘴中速度场,速度矢量场,喷雾几何形态,液体片状破裂检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共2种
下载方案
In this work the influence of the internal flow field on the liquid film was investigated. A strategy for reliable
PIV measurements inside of nozzle channels with a height of only a few hundred micrometers and at flow
velocities of several m/s has been developed. These PIV measurements provided 2 dimensional snapshots of the
velocity field inside the nozzle as well as velocity- and fluctuation-profiles across the channel. The development
of the channel flow could be observed along the channel length at laminar and partly turbulent flow conditions.
Disturbances were introduced to the flow field by inserting a wire into the channel flow. PIV measurements
showed the resulting change of the nozzle flow (in the wake of the wire and without wire, respectively). The
resulting effects on the free liquid film were observed using back-lit photographs and perpendicular lightsections
through the film surface. In the case of the undisturbed nozzle, velocity fluctuations occurred mainly in
the boundary layer and the fluctuations in main streamwise direction were dominant. The free liquid film of this
nozzle was smooth at the exit and only at higher Re numbers the growth of surface waves could be observed
further downstream. The nozzle with inserted wire showed a high level of velocity fluctuation in the center of the
flow. Here, the fluctuations normal to the walls were of the same magnitude as the fluctuations in streamwise
direction. The liquid film of this nozzle was roughened directly below the nozzle exit, even at low Re numbers.
The high level fluctuations normal to the wall are assumed to play the dominant role in this process. These
measurements demonstrate the influence of the internal flow field on the liquid sheet. The results of the present
work agree well with recent experiments of Heukelbach and Tropea [1] and supplement the existing
experimental data which for example can be used as input or validation of numerical simulations.
北京欧兰科技发展有限公司为您提供《喷嘴中速度场,速度矢量场,喷雾几何形态,液体片状破裂检测方案(粒子图像测速)》,该方案主要用于其他中速度场,速度矢量场,喷雾几何形态,液体片状破裂检测,参考标准《暂无》,《喷嘴中速度场,速度矢量场,喷雾几何形态,液体片状破裂检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
我要纠错
