流体中速度场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度场
关联设备
共3种
Simultaneous local jitter, 2-D wavefronts and accelerometer measurements were performed in the flow over a flat-window turret at Mach numbers between 0.3 and 0.4 along a centerplane with a viewing angle varying between 90 and 118 degrees. Both local and global jitter imposed on a small- and large-aperture laser beams were measured using position-sensing devices and a high-speed 2-D wavefront sensor. A linear stochastic estimation technique was applied to separate the mechanically-related component of the jitter from the aero-optical component. Spectra of aero-optical jitter for different elevation angles and speeds were calculated and useful scaling laws were proposed. It was shown that aero-optical jitter was due to the presence of both the stationary and traveling aero-optical components. Detailed analysis of the global and the local jitter spectra and the spectral cross-correlation between them at different speeds and viewing angles is presented and discussed in details. Additionally, PIV system was used to measure the flow field over the flat window, simultaneously with the aero-optical jitter measurements.
北京欧兰科技发展有限公司为您提供《流体中速度场检测方案(粒子图像测速)》,该方案主要用于其他中速度场检测,参考标准《暂无》,《流体中速度场检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)、Imager sCMOS PIV相机。
我要纠错
