流风机中扩散放大器性能的实验研究检测方案(粒子图像测速)
检测样品
其他
检测项目
扩散放大器性能的实验研究
关联设备
共1种
下载方案
The performance of a vertical axis wind turbine with and without a diffuser was studied
using direct force measurement technique applied to a scaled model of the rotor in a
water tunnel. The experiment was conducted at different tip-speed ratios. The maximum
power coefficient for the turbine was found to be equal to 0.35 for the rotor with diffuser
and to 0.26 for the rotor without diffuser. Therefore, the maximum power coefficient was
increased by 35% when the diffuser was used in the configuration.
In the second part of this work, the flow patterns downstream of the turbine were
studied by the particle image velocimetry (PIV) technique. Six different tip-speed ratios
were considered for each configuration (with and without a diffuser). The vorticity and
the streamline plots provide insight into the flow physics in each configuration. In
addition, the swept area of a full-scale rotor was calculated for both a diffuser-augmented
and a bare turbine for a range of power outputs.
北京欧兰科技发展有限公司为您提供《流风机中扩散放大器性能的实验研究检测方案(粒子图像测速)》,该方案主要用于其他中扩散放大器性能的实验研究检测,参考标准《暂无》,《流风机中扩散放大器性能的实验研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
